Add AC, what do i need?
Old Jun 3, 2004 | 11:32 PM
S-Type1's Avatar
Default Add AC, what do i need?
I have a 92 Civic Si, w/ JRSC that i drive daily. I've been thinking of adding an AC unit to keep cool during the summer during my commutes, but whats involved with installation and how much should i expect parts to cost?
P.S. I have a race car on the side, so i dont really care about performance hits.
Old Jun 4, 2004 | 12:02 AM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Add AC, what do i need? (S-Type1)
Doesn't the Si's come with A/C stock?
Old Jun 4, 2004 | 12:09 AM
Emong3's Avatar
compressor with brackets / idle pulley and belt
condenser
evaporator
Blower (if you don't have it yet)
receiver dryer
expansion valve
auxillary fan
wiring harness
tubes for the lines
Refrigerant (R134a)
*Professional a/c installer
Old Jun 4, 2004 | 12:16 AM
S-Type1's Avatar
Default Re: Add AC, what do i need? (Emong3)
man, i'm gonna miss that huge gap in front of my header, arent i?
Do you see any problems with having an AC installed with a supercharger?
Should i bother with a used OEM kit or am i better off getting a new kit, possibly aftermarket?
Old Jun 4, 2004 | 12:42 AM
Emong3's Avatar
If you got the supercharger already, check if there is still room for the compressor and condenser. the compressor will be taking space on the lower left engine support. And the condenser and fan assy will take up space right in front of the headers. Another issue is that your A/C system may not function very well if you have an intercooler since the heat from the intercooler could affect the efficiency of heat exchange on the condenser, unless you use a more powerful auxillary fan.
Old Jun 4, 2004 | 07:50 AM
S-Type1's Avatar
Thanks, you've been really helpful! I should have plenty of room... i mean.. nothing's there!
I found this ebay auction:
http://cgi.ebay.com/ebaymotors...44977
He mentions "This auction is only for the items found in the engine bay. What you see pictured is what you are bidding on" - My question is: what doesnt go in the engine bay that i would need besides the "AC" button?
Modified by S-Type1 at 5:09 PM 6/4/2004
Old Jun 4, 2004 | 08:36 AM
NinjaBuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-Type1 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by S-Type1 at 5:09 PM 6/4/2004</TD></TR></TABLE>
You will need the evaporator and box that is under the dash. Do you sill have the blower motor in there? An as was asked earlier, I thought Si's came with a/c. Did you remove it for the supercharger? Did you buy the car like this? There is a chance you evap is still under the dash, look on the firewall on the pass side, you will see an oblong opening. If the evap is still there, you should see the ends of it.
Josh
Old Jun 4, 2004 | 09:49 AM
S-Type1's Avatar
Default Re: Add AC, what do i need? ((hybridhatch92))
92-95 civic si started at a bsae price of $13,000 - AC was optional.
My vents and heater work perfectly fine. The car didnt come with AC, so i didnt remove anything of that sort.
Modified by S-Type1 at 8:00 PM 6/4/2004
carlove
Acura TSX
Jul 11, 2018 06:01 AM
Hawaiianhonda
Acura TSX
Apr 16, 2017 11:42 AM
nickelz34
10
Aug 31, 2009 07:55 PM
masamine
Jun 25, 2004 04:10 PM
variable_x
Aug 31, 2002 11:08 PM
