VAFC Question?
Old Jun 3, 2004 | 07:03 PM
lilredhatch's Avatar
Default VAFC Question?
I just got thru building my engine also installed my new VAFC. I'm unfamilar with it and don't plan on hardly touching(until its dyno tuned) it except for stuff i have to do to it before i crank the motor. My question is will the vtec cross over that the ecu is using now be cancelled out until i set it to what i need it on or will it remain the factory ecu cross over point until i set it?
Old Jun 3, 2004 | 07:09 PM
rsmotors's Avatar
Default Re: VAFC Question? (lilredhatch)
Once you wire the VAFC up, it will use the vtec cross over thats programmed into it.
Old Jun 3, 2004 | 07:21 PM
Default Re: VAFC Question? (rsmotors)
the vtec cross over thats programmed into the ecu or the VAFC itself? Do u mean before i start up the motor i need to set the vtec also?
Old Jun 3, 2004 | 08:38 PM
Kevedge's Avatar
I believe the "stock" VTEC engagement point on the VAFC is 5800. So once you go to crank your motor over, it will activate at 5800. You can set it to whatever you want before you crank the motor or after. It should be set automatically.
Old Jun 4, 2004 | 11:09 AM
Default Re: VAFC Question? (Kevedge)
Any follow-ups on the last post? Is he correct about the vafc automatically sets vtec at 5800? I've searched a little more about this and some say if i leave settings for vtec at 0 then it will use the stock vtec engagement...
Old Jun 4, 2004 | 11:29 PM
Kevedge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredhatch &raquo;</TD></TR><TR><TD CLASS="quote">Any follow-ups on the last post? Is he correct about the vafc automatically sets vtec at 5800? I've searched a little more about this and some say if i leave settings for vtec at 0 then it will use the stock vtec engagement... </TD></TR></TABLE>
This is for the first generation vafc right? I am pretty sure it sets it at stock 5800. I dont think there is a "0" vtec setting. It basically looks liek this....
lo&gt;hi = 5800
hi&gt;lo = 5600
Basically the lo&gt;hi means when you engage in vtec, and the hi&gt;lo is when you drop out of vtec.
xelloss
Engine Management and Tuning
Oct 28, 2008 09:35 AM
TurboB18C1
Nov 25, 2002 06:11 PM
98R-1144
Nov 4, 2002 05:12 PM
rotorhead70
Oct 25, 2002 05:12 PM
