*Searched* I keep blowing horn fuses
check to see if your horn connections (on the horn) are secure and aren't corroded. Also, you didn't mention when it happens....like does it blow when you are holding the horn button for x-minutes or when you try talking to your buddy six cars up in the traffic jam by morse code horn style? Give a little more info on when it happens.
I put the fuse in tried to make sure it worked and it did then later I checked again the same day and it didn't work. I do have an aftermarket headunit. I have had it for a while with no problems. This problem is all of the sudden.
TurboEM1
Nov 19, 2005 03:28 AM
4doorRS5spd
Audio / Security / Video
Sep 6, 2002 08:29 PM
