*Searched* I keep blowing horn fuses
Re: *Searched* I keep blowing horn fuses (YOUR MAMA)
you might want to try pulling the front bumper and taking a look at the plug and wires, sounds like wires are grounding out or together
check to see if your horn connections (on the horn) are secure and aren't corroded. Also, you didn't mention when it happens....like does it blow when you are holding the horn button for x-minutes or when you try talking to your buddy six cars up in the traffic jam by morse code horn style? Give a little more info on when it happens.
Re: (SolObsession)
I put the fuse in tried to make sure it worked and it did then later I checked again the same day and it didn't work. I do have an aftermarket headunit. I have had it for a while with no problems. This problem is all of the sudden.
TurboEM1
11-19-2005 03:28 AM
4doorRS5spd
Audio / Security / Video
09-06-2002 08:29 PM
