torn.............?
Old Jun 2, 2004 | 04:06 PM
jdmrex91's Avatar
Default torn.............?
whats up guys.....here's my problem.......i want to go b-series, the thing is i could spend 1700 on a b16 with lsd tranni and have serious torque issues or i could take a b18a block i happen to have (bad rods) and have it rebuilt for ls/vtec to make up for the lack of torque with the b16.....basically i'm torn...if ne one out there is in a similar situation or has done either i would appreciate some pro's and con's for either choice.......thankx guys
Old Jun 2, 2004 | 04:20 PM
jdmrex91's Avatar
Default Re: torn.............? (jdmrex91)
bump
Old Jun 2, 2004 | 04:49 PM
DXDOHCVTEC's Avatar
If you have the b18 block start building that up with the money I'd hate to see a good block just collect dust.
BUT on the other hand I dont think the torque issues will be as sufficient as the screaming top end of a B16.
just a couple $0.01
Old Jun 2, 2004 | 04:58 PM
Bserieskllr's Avatar
well if the block is ready for ls/vtec i'd build that....if not get the b16a swap then build the b18a block. then you have a ls/vtec with lsd tranny.
Old Jun 3, 2004 | 09:10 AM
jdmrex91's Avatar
Default Re: (DXDOHCVTEC)
thing is the block isnt setup for ls\vtec......a local shop does excellent work just a little pricey.....does ne one know where i can get a ls\vtec prep kit.....and what kind of pistons, rods, rings, etc... i should run if i go ls\vtec
for all the good advice
Old Jun 3, 2004 | 09:42 AM
phatrick2332's Avatar
just get a good set of LS rods, then some ctr, or 1g b16 pistons, a b16 head, and then buy the ls/vtec oil line kit and everything to run it. Get a nice set of cams and ur ready to go on a decently cheap build.
or just build the ls, my buddy put down 162whp with crower 3's, springs,retainers and a dc sports header.
Should be doing mid 180s just with the addition of b16 pistons.
Old Jun 3, 2004 | 10:14 AM
jdmrex91's Avatar
Default Re: (phatrick2332)
what would the diff in compression be between the ctr pistons and 1g b16 pistons.....and is the stock crank gonna hold up for the higher R's........from a better set of cams (ctr\itr)............
for all the advice
Old Jun 3, 2004 | 11:28 AM
jdmrex91's Avatar
Default Re: (jdmrex91)
anybody else?
gnxpro24
Jan 2, 2011 08:09 PM
a1320addict
May 9, 2005 12:43 AM
dc-lefty
Feb 27, 2004 07:51 AM
rusteds2k
Dec 2, 2003 01:44 PM
AmauryR
Nov 25, 2001 07:09 PM
