Can a leaky booster cause high NOx?
I was just reading on the web that one of the many causes of high NOx levels are vacuum leaks. Would a leaky brake booster be considerd a "vacuum leak"?
Any other ideas on High NOx levels but other emission levels are really low.
yes a vacuum leak can casue high nox becasue it's unmeterd air and unmetred air will make a car run lean. nox is created by excessive pressure and combustion temps in excess of 2500 degrees, casue by lean conditions.
Yes, a leaky booster can be considred a vacuum leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote">yes a vacuum leak can casue high nox becasue it's unmeterd air and unmetred air will make a car run lean. nox is created by excessive pressure and combustion temps in excess of 2500 degrees, casue by lean conditions.
Yes, a leaky booster can be considred a vacuum leak</TD></TR></TABLE>
Thanks. Unfortunately, that's what I thought.
Buffalo
Nov 3, 2006 08:55 AM
