99 civic si rear swaybar problem
Old Jun 2, 2004 | 12:41 PM
vtecman's Avatar
Default 99 civic si rear swaybar problem
I have a 99 SI civic and I was trying to take off my rear sway bar to put on my suspension tech sway bar and i cannot remove my drivers side end links that connect to my lower control arm and when i spin the nut the whole stud spins with it so i re-tighted it up and now i hear a clanking noise everytime I hit a bump. Does any body have any suggestions on how they got theres off. Detailed picks would help me out a lot if anybody has them installing there suspension tech sway bar on a em1 Si. Thanks
Old Jun 2, 2004 | 12:46 PM
mjrage's Avatar
Default Re: 99 civic si rear swaybar problem (vtecman)
I got mine off using an impact on the bottom and a ratchet on top with an extension. Other than that, I took a grinder to it and just ripped the bolt out. It was rusted to ****.
Old Jun 2, 2004 | 12:49 PM
bbarbulo's Avatar
5 or 6 mm allen key goes in the same side of the endlink as the nut, so use a open end wrench or a pass-through socket. also, apply WD40 liberally
Old Jun 2, 2004 | 03:29 PM
greenf1's Avatar
Default Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo &raquo;</TD></TR><TR><TD CLASS="quote">5 or 6 mm allen key goes in the same side of the endlink as the nut, so use a open end wrench or a pass-through socket. also, apply WD40 liberally</TD></TR></TABLE>
what he said.
Old Jun 2, 2004 | 03:31 PM
JDM PRO's Avatar
Old Jun 2, 2004 | 08:48 PM
vtecman's Avatar
Default Re: 99 civic si rear swaybar problem (mjrage)
Thanks guys I will try that. Does anybody have any pics of the suspension tech rear sway bar on there em1 SI I did a search and it wasn't very helpful so pics will be greatly appreciated.
Old Jun 2, 2004 | 09:19 PM
99EBPSI4ME's Avatar
you need a alan key and open socket wrench.....
Old Jun 2, 2004 | 10:31 PM
Mighty's Avatar
Its a 5mm Allen wrench. I just installed an ITR bar with Si endlinks on my EK today.
Old Jun 3, 2004 | 07:22 AM
greebler's Avatar
Default Re: (Mighty)
That liquid wrench spray is your friend, hose that bitch down and let it sit for ~10 min. Don't distroy the endlinks, you can sell them really easily.
Milab21
Suspension & Brakes
Feb 19, 2009 12:51 AM
killa99si
Aug 31, 2006 04:19 AM
civexspeedy
Aug 25, 2006 02:43 PM
2khb
Apr 28, 2004 06:50 AM
EGTeK
Nov 8, 2002 03:37 PM
