99 civic si rear swaybar problem
I have a 99 SI civic and I was trying to take off my rear sway bar to put on my suspension tech sway bar and i cannot remove my drivers side end links that connect to my lower control arm and when i spin the nut the whole stud spins with it so i re-tighted it up and now i hear a clanking noise everytime I hit a bump. Does any body have any suggestions on how they got theres off. Detailed picks would help me out a lot if anybody has them installing there suspension tech sway bar on a em1 Si. Thanks
Re: 99 civic si rear swaybar problem (vtecman)
I got mine off using an impact on the bottom and a ratchet on top with an extension. Other than that, I took a grinder to it and just ripped the bolt out. It was rusted to ****.
Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">5 or 6 mm allen key goes in the same side of the endlink as the nut, so use a open end wrench or a pass-through socket. also, apply WD40 liberally</TD></TR></TABLE>
what he said.
what he said.
Re: 99 civic si rear swaybar problem (mjrage)
Thanks guys I will try that. Does anybody have any pics of the suspension tech rear sway bar on there em1 SI I did a search and it wasn't very helpful so pics will be greatly appreciated.
killa99si
08-31-2006 04:19 AM
