90 hatch swap problem
Old Jun 2, 2004 | 12:01 PM
boostin4door's Avatar
Default 90 hatch swap problem
whats up i was just wondering if anyone knew what was the problem here.. i mean i think its the timing but not to sure... arite well i gotta 90 hatch std model, wired to fuel injection already, had a b16 in it then swapped a 98 obd2 LS motor in it... with the 98 manifold and 94 throttle body, running on a chipped pr3 ecu, b16 dizzy, but ok i put the motor in it starts up fine.. but when i go to give it gas it wants to shut off or sound like it wants to anyone.. but i had the same problem when i put the b16 in.. it was the timing.. but now i have the LS set at top dead center i turned the dizzy back and forth it wont run unless it totally retarted... anyone have any idea? should i check the timing one more time, and if its not that what could or would it be?
Old Jun 2, 2004 | 11:41 PM
mr. carpenter's Avatar
Default Re: 90 hatch swap problem (widebodyjaeg16b)
are you sure that you got the timing right between the crank shaft and cam shaft?
Old Jun 3, 2004 | 09:50 PM
TYPEROLLER#420's Avatar
Default Re: 90 hatch swap problem (mr. carpenter)
use a 94 intake manifold !
Old Jun 4, 2004 | 06:17 AM
Default Re: 90 hatch swap problem (Thinkaboutit)
yea well if i had one i would.. but just as the post says im using a 98** so that dosent help me too much. not to mention my friend has a 2000 si swap in his 89 si and it runs fine with the 2000 manifold.
Old Jun 4, 2004 | 07:01 AM
well try and learn the vtec is diffrent.............i had same w 99 ls in crx obd 1
ran fine w 94 manifold/tb !!!
Old Jun 4, 2004 | 07:08 AM
you got pr3 right obd 1 its lookin 4 obd1 manifold
Old Jun 4, 2004 | 09:37 AM
Default Re: 90 hatch swap problem (WANAGETSMOKEDB18C5)
[QUOTE=WANAGETSMOKEDB18C5]well try and learn the vtec is diffrent.............i had same w 99 ls in crx obd 1
ran fine w 94 manifold/tb !!![/QUOTE
...yea a pr3 ecu, is obd0 not obd1 if thats what you were trying to say.. but i am using a 94 throttle body on a 98 manifold.. all the sensors are exactly the same except for the one on top of the manifold which i dont use anyways... idk
Old Jun 4, 2004 | 09:45 AM
Bserieskllr's Avatar
what injectors are you using?
Old Jun 4, 2004 | 09:58 AM
Default Re: (Bserieskllr)
jdm b16 obd0
Old Jun 4, 2004 | 10:19 AM
Default Re: (widebodyjaeg16b)
u got problems zeek
hatchet_honda
Apr 25, 2011 06:11 AM
bpwrdeg
Oct 16, 2007 07:19 AM
Azn Kenny
Nov 28, 2006 11:34 AM
