should i build a whole motor, or just the top?
Old Jun 1, 2004 | 08:45 PM
frenchy's Avatar
Default should i build a whole motor, or just the top?
its kind of a long story, but the cliffs version is that needing new valve seals snowballed into the desire to build a new head instead - the question came about when i was talking to my friend and he said that if i put a rebuilt head on on an old block it will just make the block go out - if i get decent compression on the bottom am i wasting money putting a new head on? tia
Old Jun 1, 2004 | 09:48 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: should i build a whole motor, or just the top? (frenchy)
The short answer is no. Doesn't sound like your friend knows what he's talking about.
Old Jun 1, 2004 | 09:54 PM
S9i1R's Avatar
as long as it's not knocking & still runs strong ie: no bad rings ect. then keep your oil changed you'll be happier than a puppy w/ two peters
Old Jun 2, 2004 | 06:24 AM
frenchy's Avatar
Default Re: should i build a whole motor, or just the top? (S9i1R)
so if i rebiuld a head w/ mild upgrades, and put it back on my old block i should be okay?
Old Jun 2, 2004 | 08:15 AM
S9i1R's Avatar
yes, you should be good. BTW how many mile are on your motor right now? the only thing I'd check is the wear on the cylinder walls when you pull your head.
Old Jun 2, 2004 | 09:45 AM
frenchy's Avatar
its got about 120xxx w/ 200(+/- 10) compression
Old Jun 2, 2004 | 11:03 AM
96turboteg's Avatar
i would just do a mild build, such as a mild pnp and something like skunk2 stage 1 cams and the valvetrain if you want but not necessary. If you go overboard on the head then it wont do you much good cause your bottom end is stock.
Old Jun 2, 2004 | 01:10 PM
frenchy's Avatar
Default Re: should i build a whole motor, or just the top? (96turboteg)
thats what i was intending - pnp, upgraded valve train and maybe a ctr intake cam
tealchief
Dec 15, 2008 07:51 AM
B18B00st
Jul 1, 2005 09:50 PM
BeavisB16
Feb 22, 2003 12:28 PM
servion
Feb 11, 2003 10:06 PM
20lb.teg
Oct 11, 2002 11:25 PM
