My Vtec is weird!
Its like this. My b16 is strange. I hear it kick in it wants to go but, it feels like there is pressure holding it back, or like as if something was clogging up. It hits and it holds like its going but your not. Im not sure what it could be, you can hear it engage, you can feel it for a second. But then when you try to get on the gas it guts out on you and feels like it can't get enough fuel, or oil in the selinoid. Driving me crazy any thoughts would help me greatly!
i already tryed a different ecu. My obd1 pr3 is in perfect condition
cables are fine. I have iridium plugs love um!!! Grounds are all good. Anymore ideas!!!!!!!!!!!!!!!!!!!!
have u tried taking off the vtec soleniod and cleaning that little screen. that used to get dirty on my last car and it made a big difference. also is you oil pressure ok.
and has your car always been doing this,did u ever run your car before the obd1 conversion. maybe u did somthing wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyosoeg6 »</TD></TR><TR><TD CLASS="quote">have u tried taking off the vtec soleniod and cleaning that little screen. that used to get dirty on my last car and it made a big difference. also is you oil pressure ok.
and has your car always been doing this,did u ever run your car before the obd1 conversion. maybe u did somthing wrong.</TD></TR></TABLE>
ill do that first also
Ya those solenoids tend to get dirty, you need to clean it
a dir my plugs are good, my obd1 conversion is fine, otherwise id have codes.
I haven't changed the fuel filter though, nor checked the little screen. ill try this thanks.
CHECK OIL LEVEL!! Also check to make sure that your oil pan isn't smashed in at all. It could plug up your oil pickup. If your oil level is low, VTEC will not engage or feel like it's starving for something.
[QUOTE=USDM 4G VTEC]
Also take out the oil pressure switch and blow the **** outta it I had to do that to my type r motor cause I was having the same problem and it worked correct after that
I dont know why everyone loves those iridium,platinum spark plugs, i find
the Honda engines perform better with stock NGK, my opinion, always use to have intermittent driveability problems on my old civic with the b16 swap i had in her,
till tech at work told me to start with the plugs, he hates those spark plugs unlessd
vehicle comes from factory platinum,iridium plugs,
RockinthEFhatch
Dec 27, 2007 07:25 AM
