t 3 turbo question
i wanted to know if a t3 turbo would be good for a civic with a SOHC motor..i was thinking about a t25 turbo for faster spool but i am getting a good deal for this t3 turbo...please help me out
OMG!!!11
Pay extra attention to the bits about how compressor size directly affect charge temps, which directly affect power per "psi." There is a similar relationship on the exhaust side, if the turbine spools too early it chokes the engine and doesn't let it breathe as well as a laggier setup.
I don't want to tell you what to get. You need to define how much power you want and look at a few dyno graphs and read a number of threads to figure out which turbo is for you and your setup. Searching will help you do this. Good luck.
