How to do Ignition Key Cylinder Removal
Old May 31, 2004 | 06:20 PM
DerangedEG's Avatar
Default How to do Ignition Key Cylinder Removal
Hey guys my 94 GSR was stolen and the theives cracked up the steering column. I am replacing the ignition key cylinder where they broke it.
How do I take out the old stock ignition key cylinder and put it in an unbroken new one. I got a new one from someone on here but it doesn't have a key, how do I remove it so I can put my old one in and replace it. I searched but couldn't find anything definitive.
TIA.
Old Jun 1, 2004 | 02:04 AM
bigxclumzy's Avatar
Default Re: How to do Ignition Key Cylinder Removal (DerangedEG)
take it to a locksmith they can repin your good ignition and you can still use your existing key.
Old Jun 1, 2004 | 06:17 AM
DerangedEG's Avatar
Default Re: How to do Ignition Key Cylinder Removal (bigxclumzy)
Thanks dude. I guess that is the EASIEST way.
Old Jun 1, 2004 | 06:49 AM
RedlinedVTEC's Avatar
No it's not the easiest way, you can do it yourself it's pretty easy. I've had to do it 5 or 6 times now. For the first time removal take off the steering column plastic, steering wheel, srs reel if necessary, and combo switch. Then use a dremel to slot the heads of the two screws holding the key cylinder in place. Disconnect the ignition switch and other wire from the key cylinder and pull it out. If you want to take it apart there is a small button on the top that you push in while you have the key in it and pushed in (between the 0 and I position) cylinder slides right out. Any questions feel free to pm me.
Old Jun 9, 2004 | 07:39 PM
2decypher's Avatar
Default Re: How to do Ignition Key Cylinder Removal (RedlinedVTEC)
How do you put it back in again?
My EJ Civic was recovered, and the mechanic put in a new ignition lock and didn't swap the cylinder from the old lock. Following your instructions, I was able to get the cylinder out, but not back in.
Old Jun 10, 2004 | 04:11 PM
Default Re: How to do Ignition Key Cylinder Removal (2decypher)
Make sure you have the key pushed in... took a little playing around for me to figure it out the first time I did it.
Old Nov 17, 2004 | 02:59 PM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
part of what im looking for, but..
pendejon
11
Nov 23, 2016 09:34 PM
mucjbpe
May 8, 2014 06:38 PM
rugimpy
Aug 21, 2012 10:12 AM
1sikhatch
Apr 8, 2010 08:58 AM
b18cEK
10
Apr 6, 2006 06:23 AM
