timing belt tensioner question's
Old May 31, 2004 | 04:29 PM
Grip's Avatar
Default timing belt tensioner question's
when is a good time to replace the timing belt tensioner?
what do i look for or check to see if its worn or needs replacing?
the one in my car is real hard to move and it feels kinda grity when i move it manually..i remember when i installed my motor it was pretty easy and smooth moving..ive allready decioded i need a new one i just wanna know if theres any way to tell for sure if it needs replacing?
Old May 31, 2004 | 05:25 PM
DonF's Avatar
Default Re: timing belt tensioner question's (Grip)
You have allready answered your own question. Replace it.
Old Jun 1, 2004 | 04:56 AM
Grip's Avatar
Default Re: timing belt tensioner question's (DonF)
Old Jun 1, 2004 | 01:57 PM
chad174's Avatar
Inspect the actual spring and see if it is bent or damaged in any way. But given the amount of damage a bad belt tensioner can do, ,it would be a wise decision to spend the 10 bucks and get a new one. I had a $2,000 dollar head get ruined by a bad tensioner.
Old Jun 1, 2004 | 06:20 PM
Grip's Avatar
Default Re: timing belt tensioner question's (chad174)
yea i found out the hard way also..but i was very lucky and the only thing i have to replace was the timing belt since i was at 1,000 rpm when it broke..so i decided to build the whole head anyways ..thanks for the info guys..i found a tensioner for 33 bucks brand new
JDM_Andrew
Jan 16, 2006 03:30 PM
jsnm
Aug 29, 2005 09:44 AM
dunkd
May 27, 2005 07:48 PM
Greg123
Mar 18, 2003 05:59 PM
