Timing Belt Tensioner a must with Timing belt Replacement?
Is the Timing Belt Tentioner a must when replacing the timing belt?? or can I get away with out replacing it?? I dont think it's spring loaded so can't really wear out in that matter....I only see if the bearings are bad in the pulley itself I should of course buy a new one. correct?
Re: Timing Belt Tensioner a must with Timing belt Replacement? (Greg123)
definately not necissary...only replace it if it no longer tensions the belt, or does not spin freely
[Modified by DragII, 5:26 PM 2/3/2003]
Re: Timing Belt Tensioner a must with Timing belt Replacement? (Pampo with pro V)
How do you know when the tensioner needs to be replaced?
I will be replacing the Timing belt on my GSR motor before I drop it in my Cx. The motor only has 53k (1998) on it so I am thinking it should be good to go
