How to remove water from engine? hehe
Old May 31, 2004 | 10:54 AM
TimsTeg's Avatar
Default How to remove water from engine? hehe
I was coming home yesterday during a very huge rain storm and hit a giant puddle that ended up killing my car ( i have a cold air intake by the way). I pulled over to the said and it still had full battery power, but wouldn't crank at all, it sounded like the starter was trying to work but couldn't turn the flywheel. I took off my intake tube and found a small amount of water inside the tube (uh oh). I tried so many times to start it that the battery died. This is the point that i had it towed home. After letting it sit over night it still won't do much while jump started. It sounds like that starter is trying to turn the flywheel, it just can't do it. I can see the belts start to turn then just stop. What can i do to see if i hyrdolocked my engine or not? Anyway to get the water out of there?
Old May 31, 2004 | 11:11 AM
hashiriya's Avatar
Default Re: How to remove water from engine? hehe (TimsTeg)
I'd try to spin the engine by using a rachet on the crank pulley. If you have a really hard time, remove the spark plugs and try again. I hope you engine is ok.
Old Jun 1, 2004 | 08:37 PM
spoonfed95's Avatar
Default Re: How to remove water from engine? hehe (hashiriya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hashiriya &raquo;</TD></TR><TR><TD CLASS="quote">I'd try to spin the engine by using a rachet on the crank pulley. If you have a really hard time, remove the spark plugs and try again. I hope you engine is ok.</TD></TR></TABLE>
Heres the key, should turn right over and shoot water stright up and out of the Cylinders.
Old Jun 1, 2004 | 08:42 PM
IVI's Avatar
IVI
Default Re: How to remove water from engine? hehe (spoonfed95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfed95 &raquo;</TD></TR><TR><TD CLASS="quote">
Heres the key, should turn right over and shoot water stright up and out of the Cylinders.</TD></TR></TABLE>
Old Jun 1, 2004 | 08:52 PM
1Quikgsr's Avatar
i have seen some very bad damage when water gets sucked in. bent valves ie even worse. good luck.
Atheist
Dec 1, 2015 07:07 PM
masterquo
Other Make Vehicles
Oct 28, 2014 05:54 PM
prelude964
Sep 27, 2005 03:11 PM
i3luedi2agon
Nov 19, 2004 07:39 PM
LOWLIFEHATCH
Dec 18, 2003 07:52 AM
