drivin a turbo car w/ no IC???
Old May 30, 2004 | 08:54 PM
Superdragr45's Avatar
Default drivin a turbo car w/ no IC???
i have seen that the Greddy kit comes with no IC......can i drive without it and still have some decent power???? (sorry about this mods.........curiousity).
Old May 30, 2004 | 09:00 PM
Luserkid's Avatar
Default Re: drivin a turbo car w/ no IC??? (Superdragr45)
I heard its not good to drive without a IC for both the motor and the car. If needed go to the junkyard and get a Jetta 1.8T SMIC atleast.
Old May 30, 2004 | 09:33 PM
OnlyHJC's Avatar
just dont boost more that 8psi.
Old May 30, 2004 | 09:46 PM
Default Re: (O.G.RENR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G.RENR &raquo;</TD></TR><TR><TD CLASS="quote">just dont boost more that 8psi. </TD></TR></TABLE>
thats the plan i had cuz im gonna start with installing the kit then saving up until i can get the IC and a good BOV
Old May 30, 2004 | 09:51 PM
DJ_SaNdOz's Avatar
Default Re: (Superdragr45)
it's probably fine as long as you're not dragging it constantly, and don't live in the south where 100+ degree temps are the norm, but def don't boost more then 7-8 psi. i'd suggest asking this ? in the FI forum.
Old May 30, 2004 | 11:15 PM
I'll cut ya!'s Avatar
Default Re: (DJ_SaNdOz)
i would recommend SOME form of intercooler, sidemount, front mount, whatever. Id never trust any car @ 8psi with no intercooler. pretty much any OEM intercooler will do the job. Porsche 944 turbo and Starions come with big front mounts.
Old May 31, 2004 | 03:01 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (I'll cut ya!)
you can run it without an IC, but it's not safe to run a decent amount of boost without one.
Old May 31, 2004 | 05:07 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote"> i'd suggest asking this ? in the FI forum.</TD></TR></TABLE>
my votes in!
Old May 31, 2004 | 06:08 AM
2manycars2choose's Avatar
Default Re: (Built B16A)
I have searched about this kit here and I too was looking to find out how well the kit runs completly stock. Well most people said they really liked it and that it gives great power without an intercooler. I dont think greddy would make the kit if peoples engines were blowing up. Do a search and read what others have said.
Old May 31, 2004 | 06:39 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">
thats the plan i had cuz im gonna start with installing the kit then saving up until i can get the IC and a good BOV</TD></TR></TABLE>
Does that mean you dont have a BOV ? Thats more important then a intercooler, youll blow your motor without one.
Old May 31, 2004 | 06:59 AM
MooreBoost's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Does that mean you dont have a BOV ? Thats more important then a intercooler, youll blow your motor without one. </TD></TR></TABLE>
Not if you keep it under 6 pounds. The good part about running no IC under 6 pounds is the throttle response, and because you can run such a small turbo the boost will be instantaneous, and almost feel like a really strong N/A motor.
Old May 31, 2004 | 07:07 AM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> Thats more important then a intercooler, youll blow your motor without one. </TD></TR></TABLE>
hahaa.. no you wont.. wow.. you need some forced induction classes too..
a blow off valve only escapes pressure at the throttle body. thus meaning, no extream pressure between the compressor fins, and throttle body butterfly.
over time.. yes, it will hurt 1 or the other.. it will not blow your motor. worst case sanareo, you bend a few compressor fins, and start carving away at the inisde of the turbo snail...
spend some time in the FI forum guys.. you'll be surprized.
Old May 31, 2004 | 07:55 AM
Luserkid's Avatar
hmm... i always thought that if you boost you need a BOV so you dont push to much air into the cambers next time you open throttle, which would cause you to run to lean and blow a hole in a piston. Guess i was wrong.
Old May 31, 2004 | 08:13 AM
snailpoweredEK's Avatar
nah, you'll kill the turbo but it won't blow the motor.
Old May 31, 2004 | 08:14 AM
Blaze45's Avatar
Brrraaaap!
W/o a BOV, you get compressor surge and thats HARD on the turbo. It can actually cause the turbine to spin backwards if your running larger amounts of boost and the BOV doesnt do its job.
Blaze
Old May 31, 2004 | 08:18 AM
SOHC_MShue's Avatar
nah its to save the life of your turbo man. I think you will be fine without the intercooler on the greddy kit as long as your under 7psi. I'm running 6psi right now with some ghetto *** charge pipes and a sidemount intercooler mounted in the engine bay where the cai usually goes into( which probably means it isn't doing ****...just sitting in the heat). This is only a temporary setup, but it runs fine for now until i get my new charge pipes and a front mount. It actually pulls much stronger than i thought it would.
Old May 31, 2004 | 09:50 AM
red91sit's Avatar
You might want to just hook up your windshield wiper fluid pump to squirt water into your charge piping and just hit that when your putting a lot of load on the motor.
Old May 31, 2004 | 08:38 PM
OnlyHJC's Avatar
Default Re: drivin a turbo car w/ no IC??? (red91sit)
oh ya go ahead and flood your engine with water. you need a special mist tip for water injection. i wish it was that simple
Old May 31, 2004 | 09:53 PM
Built B16A's Avatar
Default Re: drivin a turbo car w/ no IC??? (O.G.RENR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G.RENR &raquo;</TD></TR><TR><TD CLASS="quote">oh ya go ahead and flood your engine with water. you need a special mist tip for water injection. i wish it was that simple</TD></TR></TABLE>
you guys are all gay.. the water injection cooling topic is for the intercooler only... he didnt' say he was going to shoot water into the inlet to the turbo, or into the filter... come on now..
Old Jun 1, 2004 | 03:53 PM
red91sit's Avatar
Default Re: drivin a turbo car w/ no IC??? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
you guys are all gay.. the water injection cooling topic is for the intercooler only... he didnt' say he was going to shoot water into the inlet to the turbo, or into the filter... come on now.. </TD></TR></TABLE>
Honestly i can't tell wtf you mean but heres'a good topic about the different kinds of water injection.
http://www.homemadeturbo.com/f...44932
rustydusty1717
Apr 19, 2008 05:47 PM
djeclipzjv
28
Feb 25, 2007 01:50 PM
coupon
Dec 22, 2004 10:16 AM
ih8danoles
May 20, 2004 09:23 AM
Arsenal
Oct 13, 2003 06:55 AM
