Codes: 15, 21, and now 3. IGN, VTEC, and MAP help.
Old May 30, 2004 | 12:38 PM
Luserkid's Avatar
Default Codes: 15, 21, and now 3. IGN, VTEC, and MAP help.
I hope that title is ok, i wasnt sure what to title it.
Anyway resently i went turbo and that was great and all. But now im getting fucked because im throwing same codes that i was throwing 2 or 3 months ago, and now i have a MAP sensor code. (go figure im boosting without a missing link or check valves)
Im not to worried about the MAP sensor ill deal with that later. And im not really worried about the VTEC either cause when i had this problem before once code 15 went away everything went away with it. (i was throwing 6 codes last time.)
Heres my last thread: https://honda-tech.com/zerothread?id=791168
Now im throwing 15 again. I checked the 2p on the dizzy and there fine, showing a good 12v number.
Checked the ECU couldnt really get a ohm number out of it (my volt meter is kind of spacy when it comes to ohms).
Im thinking i need a new dizzy because this one that i had was rebuilt. Last time i had this problem and i tried a B16 dizzy and the problems went away.
If i get a new dizzy do you guys think it would make the problems go away? If i get a new dizzy would any DOHC VTEC dizzy work? (like a B16 or a type r or another GSR?) LMK cause this is my daily driver. (B18C)
TIA (**** i hope that made sense what im asking for)
Old May 30, 2004 | 01:51 PM
Luserkid's Avatar
Default Re: Codes: 15, 21, and now 3. IGN, VTEC, and MAP help. (Luserkid)
up.
Old May 30, 2004 | 05:32 PM
Luserkid's Avatar
You gotta be shitting me, no one knows what would fix my problem?
Old May 30, 2004 | 07:34 PM
Luserkid's Avatar
last bump and then i give up and ill just get a new dizzy. If these codes come back with the new dizzy, ill be very pissed.
Old May 30, 2004 | 09:56 PM
JDMlyfestyle's Avatar
Ignition output signal. id check all the ignition components. Most likely a failing coil or a Bad ICM. has the car been mis firing lately?
Old May 31, 2004 | 06:40 AM
Luserkid's Avatar
Default Re: (JDMlifestyle)
The cars been bogging, stalling, **** you name it its been doing it. But i checked the blk/yellow wire and there good.
Old May 31, 2004 | 09:48 AM
bust out the good ole manual. did you do a ohm reading on the coil? and on the ICM.
Old May 31, 2004 | 10:43 AM
Luserkid's Avatar
Your talking about the yellow/blk test to find out if the ICM works right? It came back with good numbers.
Nfire247
13
Aug 4, 2007 08:35 PM
IVI
Aug 26, 2004 01:04 PM
CiViC SiR
Mar 18, 2003 09:46 AM
Xsi
Sep 23, 2002 07:50 AM
Frosty_spl
Feb 12, 2002 02:06 PM
