pulling axle from midshaft, searched for 20 minutes
Old May 29, 2004 | 04:23 PM
Bense's Avatar
Default pulling axle from midshaft, searched for 20 minutes
does anyone know how to pull axle from the midshaft? I've been trying for the past hour and a half with no luck.
Old May 29, 2004 | 04:26 PM
paybac4223's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (bense)
you need a fat azz flat head heavy duty screw driver... pop it between the axel and half shaft and that should do the trick...
Old May 29, 2004 | 05:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
i use a hammer and a prybar. line up the prybar on the inner joint. then hit it really hard and the axle will "walk" out. h.t.h.
Old May 29, 2004 | 05:40 PM
Luserkid's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (boostedcivicsir)
https://honda-tech.com/zerothread?id=382416
Old May 29, 2004 | 05:41 PM
VWkila's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=382416</TD></TR></TABLE>
Old May 30, 2004 | 08:40 AM
Bense's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (VWkila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
i read that, and it says nothing about the midshaft.....it deals with they passener axle.
Old May 30, 2004 | 08:50 AM
tominos's Avatar
the last time i did it, i just yanked on it really hard
Old May 30, 2004 | 08:56 AM
Moe's Avatar
Moe
Get a large socket, 32mm or something larger. Put it into where the Axel connects to the halfshaft, and hit it with a hammer.
It should seperate the two, my friend found this here on HT last year. DOnt know the exact thread but it worked like a charm. 5 wacks and we were done.
Old May 30, 2004 | 09:07 AM
ekb18cCivic's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (Moe)
pops out almost the same way as the passenger side does... get a pry bar inbetween the end of the axle and where it connects to the intermidiate shaft an pry it out... it will pop right out
Old May 30, 2004 | 04:19 PM
VWkila's Avatar
Default Re: pulling axle from midshaft, searched for 20 minutes (ekb18cCivic)
It's in there pretty tight. I had to pry it out with a BIG pry bar.
Deano_D aka "Brick Top"
18
Dec 11, 2007 02:49 PM
B18CYAAA
Apr 23, 2007 08:38 PM
madmanmulligan
10
Aug 25, 2006 03:35 PM
ahloung
15
Mar 14, 2006 11:52 AM
K-Spec
Jun 14, 2005 02:09 PM
