Stock grounding locations??? how many and where?
i know of the ground coming off the neg side of the battery and the on coming off the valve cover to the front rad support. what other grounds are there and where are they located? only thing i found when searching was regarding grounding kits.
Pete
Pete
there's also a ground right infront of the Valve Cover ground... it's connected to the head right between it and PS pump.
ok so now i have 4 grounds total:
1.) off the battery to the frame of car
2.) off the valve cover and to the rad support
3.) off the tranny by the starter
4.) between the head and the ps pump
am i missing any others? i am suspecting my electrical problem to be a bad ground so i am going to replace the grounds.
btw, does anyone happen to have a pictures of ground # 3 and 4?
thanks for the help guys
Razr2
Oct 15, 2008 06:31 AM
