Checking my Ignition Timing, VIDEO!!
Old May 29, 2004 | 11:25 AM
FredoSP's Avatar
Default Checking my Ignition Timing, VIDEO!!
I recently went to Pep Boys and bought a timing gun.
my question is, when the gun is set to 16 degrees advanced, I see the white mark line up with the notch, but when I clear out the 16 degrees from the gun (0 degrees) I see the red mark line up. Is this the way everything should be on a stock B16A2? I'm just making sure everything is golden before I go to dyno.
Here's the video, half way through I cleared the timing to 0 (on the gun) and you'll see the white mark jump to red. You need Quicktime, also make the video double size (it will help to see).
http://198.38.12.245/~fred/civic_time.MOV ~ 2.2 MB
Let me know what you think, thanks.
Old May 30, 2004 | 08:42 AM
TOFU.man's Avatar
Default Re: Checking my Ignition Timing, VIDEO!! (FredoSP)
Yes that is correct you timing is right, that is the way it is supposed to be you just bought a really fancy gun so you can set timing off TDC.
Juans_MX3
Apr 21, 2011 11:05 AM
blackbndt
Oct 4, 2009 10:20 AM
d15b7racer
May 7, 2006 04:10 AM
FredoSP
May 30, 2004 07:40 AM
