Timing belt problem
Old May 29, 2004 | 11:07 AM
Rod.'s Avatar
Default Timing belt problem
Ok i tighten my timing belt and it is tight on the front side. The side that goes around the tensioner and water pump it is not as tight as the front. I can wiggle it just a little. Does that side have to be tight also liek the first one i described??
Old May 29, 2004 | 01:06 PM
Rod.'s Avatar
Default Re: Timing belt problem (redturbocivic)
someone out there
Old May 30, 2004 | 05:51 AM
Rod.'s Avatar
I am using a gsr timing belt, with gsr water pump,gsr oil pump on a 96 ls block.
B18 CYA
May 11, 2005 03:11 PM
LSVtechnologytur...
May 9, 2005 10:19 PM
dElSleepiE
Jun 1, 2003 08:56 PM
infamousALLMTR
Feb 25, 2003 07:17 PM
