CEL 03 manifold absolute pressure help
Old May 28, 2004 | 04:47 PM
gaydm.accord's Avatar
Default CEL 03 manifold absolute pressure help
ok I've switched the map sensor twice and i keep getting the same code.
I've had the same code twice now and both times the car would shutoff before getting the code. The first time i was just driving casually making a turn. The second time was when i was driving in the neighborhood last night.
Another thing that happened was when i would give it gas it would cut off and then catch back on again, i could feel it in my pedals. could it be that i have something clogged. maybe a fuel filter?
this is in an 95 accord with a 93 h22. mods are: dc headers, carsound hi flow cat, dunk catback exhaust piping, no exhaust..(for now). any suggestions?
Old Jun 2, 2004 | 02:14 PM
update... happened again today after driving a good 30 minutes.... once again the car shutdown once we hit traffic.... i started it back up and got CEL... after that the gas started to seize up.
any help???
i will check the CEL right now...
Old Jun 2, 2004 | 02:40 PM
Ekasey's Avatar
Default Re: (gaydm.accord)
check for corrsion in the conector or check to make sure the pins are all the way in the connector and not loose. do you have a v-afc?
Old Jun 2, 2004 | 03:34 PM
i have fields.. the connections to the battery are good i just washed them and cleaned them with water and baking soda no corrosion. the pins are all intact, and the wires to the fields are still good.
Old Jun 2, 2004 | 03:42 PM
Ekasey's Avatar
doe4s the fields use the map sensor as an input?
Old Jun 3, 2004 | 02:39 PM
Default Re: (eLusive ek4)
to my knowledge it does not... thats what the diagram says. im gettin gthe same code 03 got it again today arghh..
Old Jun 3, 2004 | 02:51 PM
Ekasey's Avatar
hook a volt meter up to the signal wire of your map sensor to see it should be between.5 at idle and 2.5 at WOT
patrickstar
Oct 29, 2011 06:18 PM
crxowner
Oct 12, 2011 02:54 PM
dcfour
Apr 4, 2005 06:34 PM
ventura77
Jan 17, 2005 02:02 PM
1.8t
16
Oct 16, 2003 12:45 PM
