CEL 03 manifold absolute pressure help
ok I've switched the map sensor twice and i keep getting the same code.
I've had the same code twice now and both times the car would shutoff before getting the code. The first time i was just driving casually making a turn. The second time was when i was driving in the neighborhood last night. Another thing that happened was when i would give it gas it would cut off and then catch back on again, i could feel it in my pedals. could it be that i have something clogged. maybe a fuel filter? this is in an 95 accord with a 93 h22. mods are: dc headers, carsound hi flow cat, dunk catback exhaust piping, no exhaust..(for now). any suggestions? |
update... happened again today after driving a good 30 minutes.... once again the car shutdown once we hit traffic.... i started it back up and got CEL... after that the gas started to seize up.
any help??? i will check the CEL right now... |
Re: (gaydm.accord)
check for corrsion in the conector or check to make sure the pins are all the way in the connector and not loose. do you have a v-afc?
i have fields.. the connections to the battery are good i just washed them and cleaned them with water and baking soda no corrosion. the pins are all intact, and the wires to the fields are still good.
Re: (gaydm.accord)
doe4s the fields use the map sensor as an input?
Re: (eLusive ek4)
to my knowledge it does not... thats what the diagram says. im gettin gthe same code 03 got it again today arghh..
Re: (gaydm.accord)
hook a volt meter up to the signal wire of your map sensor to see it should be between.5 at idle and 2.5 at WOT
