stupid VAFC 2 question
Old May 28, 2004 | 11:50 AM
steronz's Avatar
Default stupid VAFC 2 question
I just finished wiring up my VAFC 2. The instruction booklet had an ECU map for EF8 - b16a and DA6 - b16a (same map, naturally), so I'm confident I used the right diagram. I'm also confident I followed that diagram exactly, and I'm pretty damn sure my connections are good. But the car won't start, nothing shows up on the VAFC (blank screen), and the ECU is throwing a code 0 (LED always on). The car ran fine before I started messing with it. Any suggestions? The only thing I can see maybe having screwed up is the direction of the diagram. I counted all the pins with the plug openings facing away from me, which is how the booklet told me to do it. Is that right?
Old May 28, 2004 | 11:57 AM
Doctor CorteZ's Avatar
Default Re: stupid VAFC 2 question (steronz)
did you set the parameters on the VAFC correctly ?
Old May 28, 2004 | 11:59 AM
steronz's Avatar
Default Re: stupid VAFC 2 question (Doctor CorteZ)
The VAFC won't turn on. So I can't set the parameters.
bad connection or improper installation.
Old May 28, 2004 | 12:21 PM
Jaker's Avatar
Check for blown fuses in the fusebox on the passenger shock tower.
Old May 28, 2004 | 12:34 PM
SM 30 Hatch's Avatar
not to sound like a *****.. but did you put power to the VAFC ??
Old May 28, 2004 | 12:39 PM
steronz's Avatar
Default Re: (SM 30 Hatch)
umm... doesn't it get power from the harness? if so, then yes, i plugged the VAFC into the harness.
Old May 28, 2004 | 12:40 PM
Default Re: (steronz)
did you confirm that you have have a good power and ground connection ?
twiztid00002
Jan 14, 2008 09:31 PM
omega_s14
Jul 27, 2007 10:49 PM
WTR
Jan 2, 2006 09:02 AM
djstain
Dec 20, 2005 06:05 AM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
