b16a2 spun rod bearing!
hei guys i can get a complete swap for my car for a pretty good price, there is everything in it, engine, tranny, harness, ecu, axles, shiftlinkage, everything i need i will get! but the engine has a spun bearing, the car it was in flipped and then engine ran while the car was upside down, i have two other parts motors with almost everything except the blocks so do i have to worry about something else about the motor or am i safe if i just buy new bearings, or is there anything else that can happen to the motor from running upside down(i donīt know for how long, but the motor ran but had a knock when it was stripped from the car).
you have two other B16 cranks? Go for it, IF you can get it for REALLY cheap. A rebuild isnt going to cost too much if its already torn down. Check to make sure the sleeves arent cracked or scored very badly, and everything is on the up and up.
blinx9900
11
May 16, 2007 01:52 PM
Spade
Jul 25, 2002 08:10 AM
