P30 is it auto or manual
Old May 27, 2004 | 09:30 PM
Sliced Beard's Avatar
Default P30 is it auto or manual
it says
37820-P30-010
470-209745
below the bar code and it has a seperate board inside the ecu that is about 3"x4" long and is connected by a 12pin wire
Old May 27, 2004 | 09:35 PM
Joseph Davis's Avatar
Default Re: P30 is it auto or manual (dirtyd463)
USDM (rectangular) or JDM (square) ECU?
If USDM, you can look at RP17. They are at the bottom left of the board when you hold the ECU with the plugs on the left. If RP17 is empty, you have a MT ECU, if not it's AT. Yanking both RP17 and RP18 from an AT ECU and replacing RP18 with a jumper wire will render it manual.
JDM, they have RP17 and RP18 like the USDM ECUs, but they are tiny surface mount components on the bottom side of the ECU's motherboard. Take a look-see, tell me what you find.
Old May 28, 2004 | 08:36 AM
Default Re: P30 is it auto or manual (J. Davis)
RP17 is empty and RP18 has a chip
thanks man that makes me happy to know that i have a manual ECU
Old May 28, 2004 | 08:37 AM
now the question is, will this ecu be fine for a LS/VTEC (GSR head) with a skunk2 intake manifold
or will i need to chip it with something hondata s100
I CRX I
Engine Management and Tuning
Feb 18, 2010 08:09 PM
umair
May 1, 2009 06:15 PM
gabR.
Apr 9, 2008 12:36 PM
Project92Hatch
Mar 30, 2003 11:58 AM
H22ACiViC
Feb 9, 2002 11:47 AM
