B16a
I own a 90 Honda Civic, with a b16a, i am wondering how difficult it would be to put this motor into my 93 Honda Civic hatch DX. it's a cable clutch and i know i would have to change that out but what wlse would i need? or is it even possible? also the block says B16A it doesn't say b16a1 like i thought it would. is it possible this is out of a 92-95?and is obd1 thanks
Modified by Jaskula1 at 4:04 AM 5/27/2004
well if the b16 says pgm-fi on the intake manifold more than likely its obd0 and if it has the raised 3 line across it then it may be obd1 ( unless manifolds were switched). You would have to convert it to odb1 ( distributor, injectors). there may be more but im hella sleepy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncvc »</TD></TR><TR><TD CLASS="quote">just get a hydro to cable mount kit from HAsport. generally this motor will drop right in to your EG w/o modifications, just get a hydro tranny!</TD></TR></TABLE>
I agree skip the trouble and get a hydro tranny, will save lots of time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem »</TD></TR><TR><TD CLASS="quote">They didnt stamp the blocks with b16a1, just b16a (first gen).</TD></TR></TABLE>
all jdm b16a does not have a number stamp
all jdm b16a does not have a number stamp</TD></TR></TABLE>
If the number starts with:
1= Xsi
5= SiR
1= Xsi
5= SiR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaskula1 »</TD></TR><TR><TD CLASS="quote">will all the axles work? and mounts?</TD></TR></TABLE>
It's different than an EF, check the EG forum.
95 civic
13
Nov 18, 2003 12:23 PM
