out with the d and in with the b
here are some pics and info about my recent swap. i went with an obd1 swap (got a pretty good deal on it), on my 96 coupe. To make things run smooth, you obviously need the 99-00 civic si rear bracket, and the front engine bracket. Also if you dont' want to do too much re-wiring (if any at all), use a 96-on ex harness. You can use the dx harness but there is some rewiring that has to be done with the iacv. You cannot use the obd1 harness on a 96-up swap because the obd1 harness's are two piece, while the obd2 is a one piece which goes straight to the ecu. Since i used an obd1 motor, you also want to get an obd2 alternator, injectors, and dizzy to make the swap all plug and play. I had to re-wire the dizzy, and it wasn't as hard as people made it out to be. As for the injectors, I used the stock civic ones as the are 240cc and they have the plugs that work with the ex harness unlike the obd1 harness. Other than that, this swap is fairly straight forward. here are the pics:
right before the d gets pulled out:
sohc out:
b waiting to go in:
powered by empty:
finished product:
thanks goes out to my buddies and my wife for all the help
sohc out:
b waiting to go in:
powered by empty:
finished product:
B series motor....hmmmmmmm!! Have fun and don't be one of those guys that think they're the **** cause they have a B series motor YOU GOT A LONG WAYS TO GO. So to that I say very nice <U>start</U>
not like it matters all that much... but i'm really diggin that metalic green D Valve cover... you going to do the B up green again?
nice work...
have fun with the nice Vtec pull over the D
nice work...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaPwr »</TD></TR><TR><TD CLASS="quote">now get a TURBO
Roger that. Turbo LS ownz j0o!
</TD></TR></TABLE>Roger that. Turbo LS ownz j0o!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OptimusPrimeX »</TD></TR><TR><TD CLASS="quote">not like it matters all that much... but i'm really diggin that metalic green D Valve cover... you going to do the B up green again?
nice work...
have fun with the nice Vtec pull over the D</TD></TR></TABLE>
He went from VTEC to no-tec... what ECU did you use? I guess you have some plugs left over since you used an EX harness?
nice work...
have fun with the nice Vtec pull over the D</TD></TR></TABLE>He went from VTEC to no-tec... what ECU did you use? I guess you have some plugs left over since you used an EX harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdanglez »</TD></TR><TR><TD CLASS="quote">::drool::</TD></TR></TABLE>
thanks for all the compliments. its been a long time coming for a b series motor for my self. i've done a few of them in eg's for my buddies and even put a few together from scratch so yes i'm very happy with the results so far. yes there are some plugs not plugged in because i'm running the stock p75 ecu. dohc no-tec yo!
