airbag light stays on? code 73?
Old May 25, 2004 | 10:59 AM
xXx Justin xXx's Avatar
Default airbag light stays on? code 73?
SRS light, not CEL!!!
stayed on when i started the car, turned the key off, started again. went out. about a month later, did it again, but never went back out. reset ecu and started it.
i checked the code and it gives 7 long flashes, 3 fast. HELP!
im tring to sell the car and want everything working first!
TIA
Modified by SOHC b00st at 12:07 AM 5/27/2004
Old May 25, 2004 | 11:04 AM
skip.two's Avatar
Default Re: airbag light stays on? code 73? (SOHC b00st)
https://honda-tech.com/zerothread?id=682412
code 73? cylinder 3 misfires?
Old May 25, 2004 | 11:42 AM
EL Vap133's Avatar
I got the same code on my Civic. I replaced the plugs, cleaned up the dist cap, made sure the rotor was in tact, reset the ecu and that took care of the code 73!
Old May 25, 2004 | 02:30 PM
Default Re: airbag light stays on? code 73? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote"> code 73? cylinder 3 misfires?</TD></TR></TABLE>
huh? not CEL.... SRS... airbags light thanks though
Old May 25, 2004 | 02:32 PM
BatuKing's Avatar
get a Helm for your car and troubleshoot it
Old May 25, 2004 | 06:32 PM
Default Re: airbag light stays on? code 73? (BatuKing)
i dont have time or money to get a helms manual. cant somebody just tell me what the helms says?
Old May 25, 2004 | 11:34 PM
BatuKing's Avatar
what car is it?
Old May 26, 2004 | 08:44 AM
1996 honda civic dx hatchback. THANKS you rock if you can tell me how to fix this!
Old May 26, 2004 | 10:42 AM
BatuKing's Avatar
Well I only have a helm for a '92-'95. sorry
Old May 26, 2004 | 10:44 AM
EL Vap133's Avatar
Default Re: airbag light stays on? code 73? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I got the same code on my Civic. I replaced the plugs, cleaned up the dist cap, made sure the rotor was in tact, reset the ecu and that took care of the code 73! </TD></TR></TABLE>
Old May 26, 2004 | 03:06 PM
^^^^^ yea thats nice bud. but read it through... dont have a CEL. i have an SRS light for the AIRBAG!
and thanks anyway man.. anybody else? this needs to be fixed in the next two days or so
Old May 26, 2004 | 05:22 PM
Chiovnidca (1:59 AM 5/27/2004): SRS code 7-3 Indicates an internal failure of the SRS control unit. But it's usually caused by low battery voltage. Have you needed to replace the battery or jump start it? Try clearing it and see if it recodes.
SOHC b00st (2:19 AM 5/27/2004): yea. i have a horrible battery..heh.. if you leave the lights on for about a full minute when not running, or the fan on(blower) for about 2 minutes with key off its dead as crap.
ill just go buy a new battery and add that to my new parts lists i guess.. hope it works
leflore
Feb 27, 2015 10:10 AM
Mentat Ghola
Jan 16, 2010 06:21 PM
Mad Hatter
Nov 14, 2005 02:50 PM
GeeSeeR
Aug 10, 2001 03:39 PM
