need a diagnosis si vous plais
Old May 24, 2004 | 08:15 AM
Team 4R's Avatar
Default need a diagnosis si vous plais
a friend filmed my car the last time i was at the track..... when i watched it i noticed puffs of white smoke exiting my exhaust during my launch....... another racer said i was puffing some white smoke down the track as well.....
i asked a mechanic about it and he immediately said i need a new head gasket. i've been keeping an eye on my oil and coolant levels, and neither seems to be dropping...
when i asked another friend of mine he first asked if i was running rich...... the setup is a factory stock (no i/h/e or internals) jdm b18c (gsr) but i do have a walbro high pressure 255lph fuel pump in the car..... and my car does backfire between shifts, so i'm sure it's pretty rich.
i have been looking into the seafoam product for a while because there is a lot of carbon buildup in my intake manifold.... i know that when one uses seafoam the car is supposed to puff white smoke out of the exhaust.........
so, my question is this: do you guys think my head gasket is going? i'm running too rich? or the motor is simply burning off carbon built-up in the head?
any guidance would be appreciated.
Old May 24, 2004 | 08:16 AM
skip.two's Avatar
Default Re: need a diagnosis si vous plais (Team 4R)
black smoke - running rich - oil
white smoke - running lean - coolant
Old May 24, 2004 | 09:49 PM
Team 4R's Avatar
Default Re: need a diagnosis si vous plais (jL iLLuZiOnz 9)
so what does that mean...? my head gasket is gone and i'm leaking coolant into the block?
Old May 24, 2004 | 09:54 PM
98k20ex's Avatar
hopefully it's just a head gasket (which it usually is) and not the head itself or the block. if your positive your coolant ain't dropping at all then i'm not sure.
Silver89crx
Nov 8, 2007 02:35 PM
98_civic_dude
May 14, 2006 07:57 PM
3rd gear vt3kc pullz hard
Jan 25, 2004 03:36 PM
Randomlude
Oct 12, 2002 03:56 PM
