C2DI
Old May 24, 2004 | 06:00 AM
bsemeyn's Avatar
Default C2DI
Alright, so i'm looking to go with a distributorless ignition setup on my '99 GSR using the C2DI from AEM. I know I will have to run multiple coil packs to achieve this, but what one's should I run and how many will I need. I was thinking the MSD blaster SS coil would work, but I am quite sure I will need four of those. Any input would help. Also, if anyone is using the C2DI hit me up, I have some questions for you.
Thanks
Old May 25, 2004 | 08:22 PM
bsemeyn's Avatar
Default Re: C2DI (bsemeyn)
someone has to know something about this...
Old May 25, 2004 | 08:32 PM
frenchy's Avatar
sorry i cant help, but im curious what your motivations are for doing this - what are you trying to achieve?
Old May 26, 2004 | 05:35 AM
bsemeyn's Avatar
Default Re: C2DI (frenchy)
a distributorless ignition is more powerful and more reliable. When my engine gets rebuilt I will be running around 20 lbs of boost so strong reliable spark is very important.
To quote aem "AEM's digital Multi-Channel C2DI is the lightest, smallest and most cost effective ignition module on the market. These units are available in four- and eight-channel configurations and are ideal for applications that utilize aftermarket stand-alone engine management systems. AEM's digital Multi-Channel C2DI is the only capacitive discharge ignition systems available with dual capacitors. This enables the AEM C2DI to produce more spark energy and spark voltage per spark than any other available CDI unit. AEM's exclusive Twin Cap technology stores the energy for two distinct spark events and allows for full spark energy for each individual sparkplug, even on high-rpm distributed Mustangs. "
lupin5
May 23, 2005 06:36 PM
shermanyang
Sep 15, 2004 05:49 PM
Bspec18
Jun 30, 2003 12:55 PM
Mr.Saturn
Apr 6, 2003 06:10 PM
Bnjmn
Nov 25, 2001 01:40 PM
