help- power windows
Old May 19, 2004 | 10:16 PM
2k1 GSR's Avatar
Default help- power windows
my power windows stopped working. i thought it was the relay so i wasted 35 bucks on a new 1. and it turned out that was not the problem. any 1 have any ideas? please help...oh ya and acura wouldnt waranty because i have an aftermarket alarm. TIA
Old May 19, 2004 | 10:19 PM
LOWNSLOW's Avatar
Default Re: help- power windows (2k1 GSR)
Check your fuses and make sure they are ok. If that doesn't work then take the door panel apart and clean the main switch. Clean the metal contacts on it. Did you smell any burning while you were driving before it went out? hope I helped.
Old May 22, 2004 | 09:01 AM
2k1 GSR's Avatar
Default Re: help- power windows (2Slow2Run)
yea actually i did smell burning...
Old May 22, 2004 | 09:02 AM
2k1 GSR's Avatar
do i have to take both door panels apart or just the driver side?
Old May 22, 2004 | 10:40 AM
LOWNSLOW's Avatar
wow you smelled burning? That sucks that means either one or both of your motors are blown/burned. Theres a way to check if the motor is still good. It involves running wires on where the motor connects to the switch. I'm not too sure. I'll try and get back with a more clear explanation later.
Old May 23, 2004 | 09:39 AM
2k1 GSR's Avatar
ok heres the thing. i have an alarm that can roll up or down the windows. when i use my alarm the windows still work. its just that while im in the car trying to use the switches that it wont do anything. so if the alarm still rolls the windows up and down it shouldnt be the motor right? thanks
Old May 23, 2004 | 09:54 AM
THE94GSR's Avatar
i had the same problem the other day with my alarm i went to where the window module for the alarm is at i disconnected the wires from it and rewired it to stock the windows are now working fine btw what alarm do u have... I have a Clifford
Old May 23, 2004 | 10:47 PM
2k1 GSR's Avatar
Default Re: help- power windows (THE94GSR)
i have a clifford alarm w/ smart windows. does your alarm still activate your windows?
Old May 24, 2004 | 02:54 PM
THE94GSR's Avatar
no it wasnt working either u should try removing it and see if the windows go down also i dont know what happend but at the same time my power locks stop working i have to check that one out but i been to lazy to see what is wrong with the locks now
Old May 24, 2004 | 03:01 PM
bubba your prison bitch's Avatar
um i had the same problem. i just took the door panel off, checked out all the wires... turns out it was something as simple as one of the wires not having a good connection..
i just dont get why people go spending all this money replacing all this **** when they think something is broken before they even figure out what's wrong..??? especially for somethin like pissing 35 bucks out the window for a relay for a damn power window when u dont even know if that's the problem... next time just give me the 35 bucks
Old May 25, 2004 | 11:21 PM
2k1 GSR's Avatar
Default Re: help- power windows (bubba your prison bitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubba your prison bitch &raquo;</TD></TR><TR><TD CLASS="quote">
i just dont get why people go spending all this money replacing all this **** when they think something is broken before they even figure out what's wrong..??? especially for somethin like pissing 35 bucks out the window for a relay for a damn power window when u dont even know if that's the problem... next time just give me the 35 bucks </TD></TR></TABLE>
ok if i knew what the problem was i wouldnt be asking. only way to find out problem is check everything. so far its not the fuses nor the relay. can u help if not then your posts are worthless.
Old May 26, 2004 | 05:40 AM
bsemeyn's Avatar
I would check the connections for everything, especially becuase you have the remote windows hooked up. More likely than not one or more connection are just bad. Also, does the place where you purchased the alarm have any warrenty on installation. Where I had mine installed offers a lifetime warr. Check it out... if all of that fails pull the motor and hook it up dirrect to a battery to see if it works. Best of luck man!
Tonyl507
Audio / Security / Video
May 15, 2011 07:07 AM
Tonyl507
Sep 11, 2010 10:18 AM
seatown206
Honda Civic (2001 - 2005)
Mar 28, 2010 06:51 PM
Jos3ph
Jan 26, 2006 05:00 PM
95GS-Racin
10
Dec 21, 2002 07:46 AM
