Qs??? about code 20 ...and unknown bolt for ground plate.
Old May 24, 2004 | 05:44 AM
hondachick81's Avatar
Default Qs??? about code 20 ...and unknown bolt for ground plate.
Please read...
https://honda-tech.com/zerothread?id=874122
Thanks for any help!
Old May 24, 2004 | 11:07 AM
JimBlake's Avatar
Default Re: Qs??? about code 20 ...and unknown bolt for ground plate. (civicgirl81)
I don't have a Civic, so this is sorta BS...
codes 41 & 65 are the heaters for the 2 different O2 sensors. It's not like 65 is 'also the O2 sensor'. It's really 'the OTHER O2 sensor'. Look for a wiring drawing for your car, check out those 2 heater circuits. Maybe they're powered off the same fuse??
I don't understand about that plate you're talking about. It almost sounds like maybe it's just a bracket to hold the wiring harness, not electrically connected to the harness at all??? Just in case it IS a ground, bolt or clamp it, or wire it to a good ground. Then clear your ECU, & see if your codes come back. It's possible that all 3 were caused by an open ground in the first place.
Old May 25, 2004 | 07:26 PM
Default Re: Qs??? about code 20 ...and unknown bolt for ground plate. (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Look for a wiring drawing for your car, check out those 2 heater circuits. Maybe they're powered off the same fuse??</TD></TR></TABLE>
yes.... my haynes manual has diagrams. I looked at some b/c I was interested in where the speedo wires ran to...I still don't understand why my speedo doesn't operate properly, and mimics at tach at idle.
Thats why I don't see how it could be the 02s.
Replacing the ELD would fix these problems??
I will go check the wires and connections more in the daylight
Old May 26, 2004 | 03:37 AM
JimBlake's Avatar
Default Re: Qs??? about code 20 ...and unknown bolt for ground plate. (hondachick81)
Check the wiring drawings to see whether those O2 sensors & the ELD share the same ground. (Find out where that ground is & clean it up.) Otherwise, they could be unrelated problems.
maiden424
13
Jul 20, 2015 03:19 PM
ame28
Dec 1, 2009 09:03 PM
candyman206
Dec 26, 2008 07:00 AM
.Hookedonhatch.
Dec 12, 2008 01:23 PM
gtlaw1
11
Jul 18, 2007 07:27 AM
