My car problems!!!!
Old May 24, 2004 | 03:52 AM
Kevin Type Si's Avatar
Default My car problems!!!!
So my car is misfiring and hesitating. The car starts up fine no problems, when you rev the car past 6000rpm it starts to misfire. The needle on the cluster starts to jump (car is neutral) and the car then stalls out.
I have tried the following:
Changed Plugs and Cable
Changed Distributor
ECU
Check my injectors.
MY set-up
LS/Vtec
Si harness
Si Distributor
Si ECU
ONe thing i have notice is that the wire on the Solenoid is cut and assembled back. Could this have anything to do with my problem.
I need help cause i'm fustrated.
Old May 24, 2004 | 04:19 AM
Default Re: My car problems!!!! (Kevin Type Si)
help
Old May 24, 2004 | 05:11 AM
civickid99's Avatar
Hey I just had this problem in my car. My car was throwing a code 73 which a cylinder 3 misfire. Did everything that you did and more. One thing I didn't do was get a compression test. Finally got one and found out that my ring was bad. I would get it checked.
Old May 24, 2004 | 05:16 AM
Default Re: My car problems!!!! (civickid99)
The rings huhuh. Thats doesn't spound good.
Did you fix your problem
Old May 24, 2004 | 05:18 AM
kKdARIAN's Avatar
Vice President/CEO
have you checked your timing?
Old May 24, 2004 | 05:43 AM
Default Re: My car problems!!!! (kKdARIAN)
No I haven't check my timing
Are you talking about my timing belt?
Old May 24, 2004 | 11:35 AM
ttt
DeleriouS25
Oct 11, 2007 10:13 PM
Ash81
Feb 3, 2006 01:43 PM
Kevin Type Si
May 25, 2004 02:30 AM
crxtreme27
Apr 3, 2003 10:35 AM
Chris_
Sep 25, 2001 07:02 AM
