My car problems!!!!
My car problems!!!!
So my car is misfiring and hesitating. The car starts up fine no problems, when you rev the car past 6000rpm it starts to misfire. The needle on the cluster starts to jump (car is neutral) and the car then stalls out.
I have tried the following:
Changed Plugs and Cable
Changed Distributor
ECU
Check my injectors.
MY set-up
LS/Vtec
Si harness
Si Distributor
Si ECU
ONe thing i have notice is that the wire on the Solenoid is cut and assembled back. Could this have anything to do with my problem.
I need help cause i'm fustrated.
Changed Distributor
ECU
Check my injectors.
MY set-up
LS/Vtec
Si harness
Si Distributor
Si ECU
Re: My car problems!!!! (Kevin Type Si)
Hey I just had this problem in my car. My car was throwing a code 73 which a cylinder 3 misfire. Did everything that you did and more. One thing I didn't do was get a compression test. Finally got one and found out that my ring was bad. I would get it checked.
crxtreme27
04-03-2003 10:35 AM
