My car is acting crazy?
Old May 24, 2004 | 03:34 AM
Kevin Type Si's Avatar
Default My car is acting crazy?
So my car is misfiring and hesitating. The car starts up fine no problems, when you rev the car past 6000rpm it starts to misfire. The needle starts to jump (car is neutral) and the car then stalls out.
I have tried the following:
Changed Plugs and Cable
Changed Distributor
ECU
Check my injectors.
MY set-up
LS/Vtec
Si harness
Si Distributor
Si ECU
ONe thing i have notice is that the wire on the Solenoid is cut and assembled back. Could this have anything to do with my problem.
I need help cause i'm fustrated.
Old May 24, 2004 | 04:51 AM
Default Re: My car is acting crazy? (Kevin Type Si)
Help
Old May 24, 2004 | 09:44 AM
slowazzhatch's Avatar
check all your grounds, mine did something of this nature, and it was the ground on the thermostat housing
Old May 24, 2004 | 10:57 AM
Default Re: My car is acting crazy? (slowazzhatch)
Thank You for you help
Old May 25, 2004 | 02:30 AM
I tried it and it worked. Thank you. You saved me alot of time and money>
dansred2000si
Feb 19, 2008 05:24 AM
mR. Vash
Sep 8, 2004 10:50 AM
Kevin Type Si
May 24, 2004 11:35 AM
Kevin Cliff
May 4, 2004 05:33 PM
hybridhatch90
Jul 28, 2002 01:56 AM
