My car is acting crazy?
So my car is misfiring and hesitating. The car starts up fine no problems, when you rev the car past 6000rpm it starts to misfire. The needle starts to jump (car is neutral) and the car then stalls out.
I have tried the following: Changed Plugs and Cable Changed Distributor ECU Check my injectors. MY set-up LS/Vtec Si harness Si Distributor Si ECU ONe thing i have notice is that the wire on the Solenoid is cut and assembled back. Could this have anything to do with my problem. I need help cause i'm fustrated. |
Re: My car is acting crazy? (Kevin Type Si)
Help
check all your grounds, mine did something of this nature, and it was the ground on the thermostat housing
Re: My car is acting crazy? (slowazzhatch)
Thank You for you help
I tried it and it worked. Thank you. You saved me alot of time and money> |
