converting my auto p28 to manual...
Old May 23, 2004 | 10:05 PM
al3e's Avatar
Default converting my auto p28 to manual...
alright im ganna remove the rp17 and rp18. but then it says to repplace replace RP18 with a jumper wire.....im not sure what the jumper thing means? just run a wire across to connect them......right?
Old May 23, 2004 | 10:10 PM
function83's Avatar
Default Re: converting my auto p28 to manual... (al3e)
nice truespin topsoul.
for the jumper you can use a small single wire and solder in between
the circuits.
basically whatever chip or diode you remove, you have to put a single
wire in its place.
Old May 23, 2004 | 10:28 PM
ABK's Avatar
ABK
Default Re: converting my auto p28 to manual... (djhatch)
make sure you don't touch the board with the iron though because it will go to ****. I did mine it worked fine, then my friend did his and he burned it.
Make sure you got a good powerfull solder.
Copper wire is good for jumperwire because you can shape it into the form you want.
Old May 24, 2004 | 06:39 AM
al3e's Avatar
alright sweet thanks guys, im doing it in a few mins hopefully it will work!
Old May 24, 2004 | 01:00 PM
Broken Gearbox's Avatar
Its alive!
Old May 25, 2004 | 10:49 AM
RabbittZ's Avatar
is that a True spin top soul? pic is too small. i tried making it bigger ( sorry fo the jack of the avatar ) but i couldnt tell. i thought it was just an ally oop TS...lol
twotonecivic
May 4, 2010 07:04 PM
94hondacivicvtec
May 8, 2007 02:50 PM
Metal Head
Apr 25, 2006 03:57 PM
90AccordVTEC
Oct 12, 2005 11:27 PM
mrnice1058
Jan 11, 2005 07:19 PM
