Where is the ECT Sensor located?
Old May 23, 2004 | 06:02 PM
Jeff1119's Avatar
Default Where is the ECT Sensor located?
I'm trying to find where my ECT (Engine Coolent Temp.) sensor is? is it the sensor coming out of the thermostat? or is it somewhere else?
Old May 23, 2004 | 06:34 PM
RedlinedVTEC's Avatar
Default Re: Where is the ECT Sensor located? (Jeff1119)
yes, it is in the thermostat housing.
Old May 23, 2004 | 08:22 PM
SAVIOVEGA's Avatar
Default Re: Where is the ECT Sensor located? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">yes, it is in the thermostat housing.</TD></TR></TABLE>
Isn't that the fan switch? The ECT sensor should be below the distributor.
Old May 24, 2004 | 06:25 AM
JimBlake's Avatar
Default Re: Where is the ECT Sensor located? (jdm wannabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">Fan switch is on the thermostat housing.
ECT sender is on the side of the cylinder head under the vtec solenoid area
the sender for the temp gauge is next to it.</TD></TR></TABLE>That's correct for my cars also. But some years they were moved around. Maybe if Jeff1119 would tell us what car/year/engine he has...
Old May 24, 2004 | 06:47 AM
SAVIOVEGA's Avatar
Default Re: Where is the ECT Sensor located? (JimBlake)
If your thermostat is stuck open, would that cause your fan not to come on ?
Old May 24, 2004 | 06:54 AM
JimBlake's Avatar
Default Re: Where is the ECT Sensor located? (SAVIOVEGA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAVIOVEGA &raquo;</TD></TR><TR><TD CLASS="quote">If your thermostat is stuck open, would that cause your fan not to come on ?</TD></TR></TABLE>Yes. But you can still check the fan's operation by jumpering the fan switch.
Old May 24, 2004 | 11:10 AM
Jeff1119's Avatar
ya sorryi was trying to post what my car was yesterday night but my computer froze and wouldn;t boot up, but anyway my car is a 92 honda civic DX
Old May 24, 2004 | 11:39 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm wannabe &raquo;</TD></TR><TR><TD CLASS="quote">The ONLY thing that is moved is the fan switch, on older cars its located on the back of the block. Otherwise everything else is in the same place.</TD></TR></TABLE>Thanks. I knew about the fan switch, I wasn't sure about the others.
jlowellintegra
Jun 10, 2011 10:18 AM
Simmerman
12
Sep 18, 2007 07:05 PM
generallee01
Jul 20, 2007 03:26 PM
lazykiwi
Jan 26, 2006 10:02 AM
Tad
Sep 26, 2005 04:55 PM
