Distributor shocked the hell out of me
Old May 22, 2004 | 11:53 PM
rotten's Avatar
Default Distributor shocked the hell out of me
Question: I am pretty sure you shouldn't be able to electrocute yourself on the distributor (casually that is), right?
Well we've been working like crazy on the CRX (LS/VTEC), trying to get it running properly, have had nothing but problems.
Well recently when I've gone to adjust the ignition timing, a few times I've gotten a nasty shock. Today I got a horrible shock way worse then the other times, made me see stars. So I'm pretty sure something is fucked with it.
Anyone know what could be wrong with the distributor that would cause this symptom? I took my LS distributor, repinned it and installed it tonight, replacing the old one, still having problems but haven't shocked myself again yet.
Not for sure if that fixed the problem or I'm still at risk for electrocution. Anyone have any information?
Old May 23, 2004 | 05:48 AM
Kal's Avatar
Kal
Default Re: Distributor shocked the hell out of me (rotten)
why didn't you take off the negative battery cable when you started working on your electrical system?
Old May 23, 2004 | 05:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotten &raquo;</TD></TR><TR><TD CLASS="quote">Well recently when I've gone to adjust the ignition timing, a few times I've gotten a nasty shock. Today I got a horrible shock way worse then the other times, made me see stars. So I'm pretty sure something is fucked with it.
The distributor cap is probably leaking spark. If you pour some water on it, the engine might stall to verify it.
Old May 23, 2004 | 07:56 AM
EE_Chris's Avatar
Default Re: Distributor shocked the hell out of me (Chiovnidca)
I've heard of using a long'ish screwdriver and a mist bottle of water??
Sit the screwdriver over the wires (obviously you're holding the insulated handle) and lightly mist that area, then slide the screwdriver to a new section and repeat....if you see spark scatter, your wire insulation has been corrupted.
Old May 23, 2004 | 11:04 AM
rotten's Avatar
Default Re: Distributor shocked the hell out of me (Kal)
You can't disconnect the negative battery terminal when you go to adjust the ignition timing--the car is actually running when you do this.
DRAGANDB1
Aug 9, 2018 06:19 PM
taguchi09
Jun 11, 2011 04:52 PM
b20turbocivic
Apr 25, 2008 08:54 PM
IntegD
Apr 2, 2004 10:16 AM
I 8 1 U 8 1 2
Sep 18, 2003 02:03 PM
