D-series dunebuggy idea.
Old May 22, 2004 | 09:12 PM
thehatchninja's Avatar
Default D-series dunebuggy idea.
Tonight i was talking to a co-worker/friend of mine and i was telling him that. Since my swap i have a spare d-series motor laying around, and i've been thinking of rebuilding it, but it i do i want to have something to put it in. So we are thinking about puttting it in a dune buggy frame.
I'm thinking of building the motor up a little bit. It's a CX motor, but i was thinking of putting D16a1 pistons in it, and an A6 head with a reground cam. That's about all, but as far as the fuel deliver we were thinking of using a dual carb setup to avoid a wiring nitemare.
My question is what would it take to convert to a carb setup on this motor? Is the A6 head a good choice?
Anyways, let me know what you think.
Old May 22, 2004 | 11:42 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: D-series dunebuggy idea. (thehatchninja)
i think it is a terrific idea.
for carbs a dual sidedraft set-up with either a TWM or fabricated manifold and perhaps a vacuum advance distributor from a first gen integra or a dizzi-less ignition set-up.
A6 head responds well to porting, camming and a good header. with carbs, and higher CR pistons the little engine will move.
go here and talk to people there, a lot of people have the carbs on their Dseries there and will provide the necessary information.
stan
Old May 24, 2004 | 11:06 AM
Default Re: D-series dunebuggy idea. (Stan D)
thanks...lotsa good stuff on there. I'm definitely registering there and starting my d-series build.
unless i buy a 50cc honda scooter instead then i'll be working on that and sell my d-block
Old May 24, 2004 | 12:59 PM
_BEN_'s Avatar
This is kinda relivant.
If you dont want a sand rail you can get one of these d series powered monster trucks. Probably for alot more though
http://www.patriot-racing.com
$17,900 maby they offer one without the engine for less.
drool
Old May 24, 2004 | 01:17 PM
Kal's Avatar
Kal
Default Re: D-series dunebuggy idea. (_BEN_)
lol wow what a monster
Old May 24, 2004 | 01:50 PM
Daemione's Avatar
Default Re: D-series dunebuggy idea. (Kal)
Ha ha . . . a "monster" "truck" . . . . :D
I bet that thing goes up on 2 wheels if you breathe on it wrong.
Old May 24, 2004 | 03:26 PM
obd2gsr's Avatar
that mini monster truck is ******* cool. looks like a huge R/C monster truck. i'd hit it...
Old May 25, 2004 | 07:39 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">Is the A6 head a good choice?</TD></TR></TABLE>
No. The 1992-1995 CX motor is an 8 valve motor. Without valve cutouts on each piston for four valves, you are going to have some REAL problems if you try to run a 16 valve head (like the A6 head). Rather than changing pistons, why not just go for a 16 valve motor? It will be cheaper.
Old May 26, 2004 | 04:32 PM
Default Re: D-series dunebuggy idea. (StorminMatt)
i'm going to be tearing down the motor anyways, to just the block. If i use the D16a1 pistons like i plan on doing i won't run into any problems right? I've been looking at my carb options, it should be pretty sweet...no wiring
The Stance
Apr 15, 2009 11:04 AM
#1151
May 10, 2005 03:01 AM
DOHClessEF-9
Jan 15, 2005 12:52 PM
91d15hatch
May 13, 2004 04:25 AM
neof69
Nov 4, 2002 04:32 PM
