Should I replace gaskets with new header?
Old May 22, 2004 | 01:50 PM
EricUSC's Avatar
Default Should I replace gaskets with new header?
I will installing a new Comptech header soon. According to the instructions, it says that I can reuse the stock gaskets if they are in good condition. There is one gasket between the header and the engine head and another one between the header and the cat. Are gaskets a wear item or is a 45,000 mile gasket just as good as a new gasket? Gaskets are metal pieces, and I don't see how they are a wear item. If there are any benefits to replacing these gaskets, I'll replace them because they are cheap and I'm super **** about my car, but if there are no benefits whatsoever, then I won't. So, are gaskets a wear item? If so, how do these metal wear out?
Old May 22, 2004 | 01:57 PM
mmuller's Avatar
Mad Scientist
Default Re: Should I replace gaskets with new header? (EricUSC)
i have used mine for like 150k and still going strong....taken it out plenty of times
Old May 22, 2004 | 02:36 PM
ragerized's Avatar
Default Re: Should I replace gaskets with new header? (mmuller)
ya, exhaust gaskets can be reused.
Old May 23, 2004 | 11:35 AM
EricUSC's Avatar
Default Re: Should I replace gaskets with new header? (ragerized)
So are gaskets a wear item or do they last forever?
Old May 23, 2004 | 11:54 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC &raquo;</TD></TR><TR><TD CLASS="quote">So are gaskets a wear item or do they last forever?</TD></TR></TABLE>
When I put on my header I didn't change the one btw the header and the enigne. I did however change the donut gasket between the header and the cat.
Old May 23, 2004 | 01:04 PM
Tbone's Avatar
I'm super **** too, but thats the only gasket I'll reuse like 3 times before replacement. I'm so **** that i change my injector O rings every time i pull my injectors.
jdmstockeg6
Sep 25, 2007 12:21 AM
gtowni3
29
May 12, 2005 03:14 PM
ANDREW D
Aug 15, 2004 05:32 PM
Loveless
Jul 29, 2003 08:41 PM
sombasol
Jul 2, 2003 01:17 PM
