Do my compression calculation seem correct?
Old Nov 8, 2001 | 07:36 AM
HX_Guy's Avatar
Default Do my compression calculation seem correct?
I knw this isnt ITR related, but I figure you guys might be able to help.
This is using a .030" with a 85mm bore gasket, stock B20 head and a piston with a dome displacment of 2.0cc.
Swept Volume - (85.0 / 2)^2 x pi x 89.0mm / 1000 x 4 = 2019.0985
Piston Dome Displacement - 0.0000x 4 = 8.0000
Combustion chamber volume - 45.0000 x 4 = 180.0000
Headgasket volume (incl. piston to deck height) - (85.0 / 2)^2 x pi x 0.8890 / 1000 x 4 = 20.1682(0.030" + 0.005" = 0.8890mm)
Compression Ratio = (volume at BDC) / (volume at TDC) =
(Swept Volume - Piston Dome Displ. + Comb. Chamber volume + Headgasket volume (incl. piston to deck height)) / (Comb. Chamber volume + Headgasket volume (incl. piston to deck height) - Piston dome displacement)
= 2211.2667/ 192.1682= 11.5069:1 Compression
Thanks
[Modified by HX_Guy, 8:44 AM 11/8/2001]
Old Nov 8, 2001 | 08:01 AM
Leo95SE's Avatar
Default Re: Do my compression calculation seem correct? (HX_Guy)
piston dome displacement = 8? 0x4=?
is dome displacement 2cc? how did you measure this?
im assuming the 89mm in swept volume = stroke
otherwise looks good.
Old Nov 8, 2001 | 08:19 AM
HX_Guy's Avatar
Default Re: Do my compression calculation seem correct? (Leo95SE)
I didnt measure the piston displacment..I "picked" the number randomly...to see which piston dome would give me my desired 11.5:1 CR...so I can tell Endyn what I need.
Yes 89 = stroke.
Old Nov 8, 2001 | 09:03 AM
Spade's Avatar
Going about it the right way with Endyn huh? Why don't ya just tell them you want the 11.5 CR and then when they give you 14:1 tell them they messed up J/K
I like yer way of thinking.
Honda Crx
Nov 3, 2005 08:51 AM
vinuneuro
Jul 30, 2005 10:51 PM
Seraph0
Jan 10, 2004 05:40 PM
rexnst9
Aug 6, 2003 12:28 PM
