secondary o2 sensor making vss sensor cel
Old May 20, 2004 | 10:50 PM
SpoolinEK's Avatar
Default secondary o2 sensor making vss sensor cel
could a bad secondary o2 sensor make the cel throw a vss sensor? i've changed the vss sensor to another one..still throwin both codes..96 ek dx..
Old May 21, 2004 | 05:21 AM
JimBlake's Avatar
Default Re: secondary o2 sensor making vss sensor cel (EG Civic)
They're pretty much unrelated to one another. The only thing I can think of is a common power circuit, or maybe their separate circuits both run thru one big connector (at the fuse box?) that's loose.
Old May 21, 2004 | 07:12 AM
Ekasey's Avatar
Default Re: secondary o2 sensor making vss sensor cel (JimBlake)
the shouldnt be on the same circuit, but they could be did soembody hack wire your car and possibly switch 2 wires
Old May 21, 2004 | 02:42 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic &raquo;</TD></TR><TR><TD CLASS="quote">could a bad secondary o2 sensor make the cel throw a vss sensor? </TD></TR></TABLE>
No, but a bad fuse could. Check the #15 fuse in the under dash fuse box, it's probably blown. I think it's a 15 amp.
vrotsos991
Honda Civic (2001 - 2005)
Jan 23, 2017 12:45 PM
00CivicSi5spd
Nov 7, 2015 10:01 AM
dices543
Oct 1, 2010 11:10 AM
rebuiltSI
Jul 24, 2007 09:07 PM
