Honda S2000 Honda S2000
S2000 Needs some help!
Old May 20, 2004 | 04:38 PM
JonV3's Avatar
Default S2000 Needs some help!
Hey guys I need some advice here. I have an 00 S. Recently it started to miss so I took it in and they said that it needed a tune up. So I said cool, well the mechanic said that one of the cylinders wasnt at normal compression, which is 160, but instead was at 75. So he said what I needed to do was pretty much pull the engine out. This does suck but I am thinking about doing a complete engine re-build with high performance everything. But would it be better just to get rid of it and get another one? (I love S200's).
I read every topic and I know that there are guys that know there **** so please help me out. And I heard about the V2 AEM cold air intakes, anybody have one? Cuz I only want the best for my baby, so if anybody knows which is the best intake let me know.
Thanks guys.
Old May 20, 2004 | 04:43 PM
VTECorona's Avatar
Default Re: S2000 Needs some help! (JonV3)
It's hard to make sense of that dude. What exactly is your question about your motor?
As for your intake question, Comptech Ice box is top notch.
Old May 20, 2004 | 04:50 PM
JonV3's Avatar
Default Re: S2000 Needs some help! (VTECorona)
well the mechanic isnt sure yet cuz my car is in the shop and still under diagnosis, but I guess what is wrong is a valve cuz he was talking about a valve adjustment. And sorry for the message im not a pro at all this technical stuff. But i am pretty sure that the engine needs to be pulled out to make the repair, so what I was thinking is why not just upgrade rings, pistons, vavle, cuz that was my intention for the car but not right away.
Old May 20, 2004 | 04:55 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonV3 &raquo;</TD></TR><TR><TD CLASS="quote">well the mechanic isnt sure yet cuz my car is in the shop and still under diagnosis, but I guess what is wrong is a valve cuz he was talking about a valve adjustment. And sorry for the message im not a pro at all this technical stuff. But i am pretty sure that the engine needs to be pulled out to make the repair, so what I was thinking is why not just upgrade rings, pistons, vavle, cuz that was my intention for the car but not right away.</TD></TR></TABLE>
Oh, I see. Definitely upgrade dude, the motor is apart and everything, put better parts in it. When anything stock breaks on you, always upgrade.
Old May 20, 2004 | 05:06 PM
evil vapor's Avatar
if compression is down on one cylinder, chances are the rings are the culprit but it can honestly be anything. If you want to rebuild the engine, what will you do with the car? What purpose will the rebuild serve?
Old May 20, 2004 | 05:08 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">
When anything stock breaks on you, always upgrade.</TD></TR></TABLE>
yikes, be careful making that statement. I'm not paid by honda but when I say the precision and maching put into honda OEM parts where honda made it or had another company make it is top notch...well besides those shitty trannys in most of the automatic V6's that really suck.
Old May 20, 2004 | 05:22 PM
VTECorona's Avatar
Default Re: S2000 Needs some help! (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
yikes, be careful making that statement. I'm not paid by honda but when I say the precision and maching put into honda OEM parts where honda made it or had another company make it is top notch...well besides those shitty trannys in most of the automatic V6's that really suck.</TD></TR></TABLE>
I thought about that as I typed it pretty much. Some parts are good to stay OEM while others it is ok to upgrade.
Old May 20, 2004 | 05:47 PM
JonV3's Avatar
I dont know I will have to see what else the damage report says, which will be sometime early tommorrow, so I will have more info for you guys to comment on, but thanks its much appreciated
Old May 20, 2004 | 07:53 PM
DR's Avatar
DR
You probably have some bent valves. Did you over-rev your engine by shifting into the wrong gear?
Old May 20, 2004 | 10:17 PM
nitrous137's Avatar
make sure the mechanic let you see the compression ratio....don't believe words ...i've been cheated years ago when i was a newbie!!!
ask the mechanic to do a leak down test too... good luck
96WhiteOnBlack
Honda S2000
17
Jan 29, 2008 12:20 PM
EJ8 GSR-T
Jul 30, 2007 10:54 AM
2000Z28M6
Honda S2000
Jan 10, 2006 05:04 AM
TheAntiEggroll
Honda S2000
Apr 12, 2004 08:36 PM
AngryTroll
Honda S2000
41
Oct 24, 2003 04:29 PM
