Running Obd2 ecu on obd1 enging
Old May 20, 2004 | 08:44 AM
blackflag188's Avatar
Default Running Obd2 ecu on obd1 enging
If i run an obd2a p72 ecu on a 94 b18c will i through a check engine light??? I current have an ek that was converted over to obd1 but need to change it back so i can pass emissions.
chris
Old May 20, 2004 | 02:50 PM
Default Re: Running Obd2 ecu on obd1 enging (blackflag188)
would someone pleasee respond!!!??
Old May 20, 2004 | 07:02 PM
anybody?
Old May 20, 2004 | 07:11 PM
Turbogixxer's Avatar
You will have a CEL
One for secondary 02 and other for CKF.
Old May 21, 2004 | 07:52 AM
Default Re: Running Obd2 ecu on obd1 enging (turbogixxer)
could I replace update the o2 and ckf to obd2? I took my car up too a place called knowledge performance and they said that basically they would put an obd2 ecu in the car and just replace some sensors in the engine and it would be fine. This sound correct?
Old May 21, 2004 | 07:58 AM
v4lu3s's Avatar
RTFM
get a jdm obd2 ecu and you may be able to get around SOME of it.
you could add a second o2 sensor, but the ckf may require a new timing sprocket, possibly new oil pump and of course the sensor itself.
jdmwojo
May 31, 2011 08:59 AM
court76wi
11
Oct 12, 2009 08:29 AM
stratedrm
Jun 28, 2007 02:12 PM
strictly.business
Nov 25, 2006 09:05 PM
Bimmerman
May 25, 2005 02:16 PM
