bout to replace axel - special tools?
Old May 19, 2004 | 06:45 PM
7808's Avatar
Default bout to replace axel - special tools?
im bout to go replace my front passenger side axel, never done it before. got a manual and a friend to help that knows about as much as me but were good at figuring stuff out. will i need any spcial tools? do i need to drain my tranny fluid? if so refill it with how much of what?(ya i know tranny fluid but what wieght or whatever) any other tips from those of you that have done it would help thanks.
90 civic dx hatch 5spd d15b2
Old May 19, 2004 | 07:05 PM
DreamAccord's Avatar
Default Re: bout to replace axel - special tools? (fuctup)
just take the axle out and put the new one in eeeezzzzzzz
Old May 19, 2004 | 07:06 PM
7808's Avatar
Default Re: bout to replace axel - special tools? (DreamAccord)
Old May 19, 2004 | 07:09 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
well if ur pulling out the passenger axle id drain the fluid first and make sure u got air tools or a long pipe for the axle nut.
Old May 19, 2004 | 07:14 PM
d357r0y's Avatar
I will tell you that you don't need a pickle fork for the lower ball joint. take a look at it, there are areas on either side of the cup where the ball joint mounts that honda put there to be smacked with a hammer. a couple o' good whacks and it usually pops free. No damage to ball joint boots and no need to buy a ball joint tool.
Old May 19, 2004 | 07:18 PM
7808's Avatar
Default Re: bout to replace axel - special tools? (d357r0y)
what kinda tranny fluid should i use when i refill it?
i hope walmart carries it cause its 10pm here.
Old May 19, 2004 | 07:38 PM
APEX CRX's Avatar
if its a stick shift >10w30 motor oil
Old May 19, 2004 | 09:03 PM
7808's Avatar
Default Re: bout to replace axel - special tools? (APEX CRX)
really? normal motor oil? huh.
ya its a 5 speed.
Old May 19, 2004 | 09:22 PM
mengo_charged's Avatar
10w30 should be fine...but fill it up with some Honda MTF or GM Syncromesh when you have the time...
Old May 19, 2004 | 09:30 PM
hahagasdcrx's Avatar
Default Re: bout to replace axel - special tools? (mengo_charged)
you need a 32mm socket to take off the nut on the end of the axle. Also a ball joint seperator and 14mm socket 17mm socket and 17mm wrench. I think that covers it all maybe a 4 way to take off your lug nuts.. Also maybe a hammer.
Old May 19, 2004 | 09:43 PM
7808's Avatar
Default Re: bout to replace axel - special tools? (90crxzcgasd)
to bad i dont have a 32mm
Old May 19, 2004 | 10:25 PM
sporkcrx's Avatar
I've never had to drain my fluid when changing axles.
Old May 20, 2004 | 12:58 AM
redlinepulse84's Avatar
i have an 88 crx si, and all the tools i used were:
open/closed wrenches:
(2) 17 mm
(2) 14 mm
socket wrenches:
(1) 17 mm
(1) 32 mm
you'll also need a breaker bar to get the hub nut off and a counter...its about an hour or an hour and half to get it done...i've just done mine...
don't forget you'll need a torque wrench too...its not so hard, have fun...
Old May 21, 2004 | 09:12 AM
7808's Avatar
Default Re: bout to replace axel - special tools? (redlinepulse84)
guess i need a puller too, me and my friend attempted it last night.. we couldnt get the bolt out for ****, the one with the castle nut and cotter pin in it on the bottom (lower ball joint?) we got the nut off but the bolt wouldnt come out. we hit it from different angles for like an hour and then quit. you guys know any tricks?
Old May 21, 2004 | 09:16 AM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">guess i need a puller too, me and my friend attempted it last night.. we couldnt get the bolt out for ****, the one with the castle nut and cotter pin in it on the bottom (lower ball joint?) we got the nut off but the bolt wouldnt come out. we hit it from different angles for like an hour and then quit. you guys know any tricks?</TD></TR></TABLE>
Hit it harder with a bigger hammer...then if that doesn't work, use a balljoint seperator, but take care not to tear or cut the boot on the balljoint.
Old May 21, 2004 | 10:41 AM
HNDAPWR's Avatar
Default Re: bout to replace axel - special tools? (96-EJ6 B18C)
A 32 mm socket is absolutely necessary. If your hammer isn't working correctly, you obviously need a bigger hammer.
funtak
Feb 21, 2008 11:31 AM
JMod
Nov 19, 2005 07:47 PM
CivicVX94
20
Sep 6, 2004 05:31 PM
DarkCyde SI
14
Apr 22, 2003 04:06 AM
REDBARON
Aug 3, 2002 04:26 PM
