did i get the right sparkplugs for my turbo b16
Old May 19, 2004 | 02:31 PM
Black Si's Avatar
Default did i get the right sparkplugs for my turbo b16
i searched and saw that many of you are using ngk bkr7e's and i looked all over the city and i could only find bkr6e-11's now are those going to work or should i get different ones?
Old May 19, 2004 | 02:34 PM
Sonny's Avatar
Default Re: did i get the right sparkplugs for my turbo b16 (Black Si)
http://www.sparkplugs.com
The 6 series plug is the same heat range as stock. You want the colder 7 series plug.
Sonny
Old May 19, 2004 | 02:42 PM
Black Si's Avatar
thanks
will i have any problems with running the stock heat range plugs?
Old May 19, 2004 | 05:19 PM
primeredbeast's Avatar
Default Re: (Black Si)
just make sure they are gapped correctly man
Old May 19, 2004 | 05:24 PM
Turboteggy's Avatar
I run BCPR7ES plugs from NGK.
Never had a problem in 3 years and a fresh set every spring.
Old Jun 4, 2004 | 02:21 PM
gsr93integra's Avatar
Default Re: (primeredbeast)
hey man...gt a question for you,ive got a B16 turbo too,im just wandering how to adjust the boost..im boosting 5lbs right and i want to go up a lil bit..thanks
Old Jun 4, 2004 | 05:24 PM
LostCRX's Avatar
Default Re: (gsr93integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr93integra &raquo;</TD></TR><TR><TD CLASS="quote">hey man...gt a question for you,ive got a B16 turbo too,im just wandering how to adjust the boost..im boosting 5lbs right and i want to go up a lil bit..thanks
you gotta be kidding me.
Old Jun 6, 2004 | 04:16 PM
Default Re: (LostCRX)
no BS man...i got the car from my cuz and hes not in the states right now so,im just trying to get some help outside.thanks
Old Jun 6, 2004 | 04:57 PM
DRIVENRacing's Avatar
get boost controler to up the boost, i run autolite 3922's or 3923 cheapest autolites work really well for me and many other round here that run turbo
Old Jun 6, 2004 | 06:26 PM
TurboBumblBee's Avatar
Default Re: (TurboHybridEG6)
i ordered 2 sets of NGK 6097 from sparkplugs.com and they are the ones your looking for.. set the gap to about .28-.30
teler86
Sep 1, 2006 12:39 PM
D16Z6TURBO
Feb 26, 2006 08:13 AM
WEldin4fun
May 11, 2005 08:00 PM
cyman83
Sep 28, 2004 01:11 PM
Got Spoool
May 2, 2004 07:56 PM
