Car smells like gas help!
Old May 19, 2004 | 10:23 AM
90SICRX's Avatar
Default Car smells like gas help!
Ok heres the get go,
When you open the door with the windows being up you smell gas, when you drive you smell gas BUT you only smell it inside the car. I've checked in the engine bay and it dosen't smell nor does it smell outside the car. It's a 90 CRX SI stock pretty much. I have had a few people tell me it might be the seals on the fuel pump or maybe a fuel line but if it was a fuel line wouldn't you smell gas under/outside the car? Car runs great thats the only problem I have. Just wanted to see what you guys thought.
Old May 19, 2004 | 11:28 AM
Monty's Avatar
Default Re: Car smells like gas help! (90SICRX)
Did you get any on your shoes at the pump? Ive done this before
hth
Old May 19, 2004 | 11:35 AM
tylercrx's Avatar
Default Re: Car smells like gas help! (Monty)
check the fuel pipes and fuel pump underneath your rear toolbox thing. thats the fuel pump and the fuel lines run around there from the driver side.
Old May 19, 2004 | 11:43 AM
krazie1's Avatar
BANNED
Default Re: Car smells like gas help! (tylercrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylercrx &raquo;</TD></TR><TR><TD CLASS="quote">check the fuel pipes and fuel pump underneath your rear toolbox thing. thats the fuel pump and the fuel lines run around there from the driver side.</TD></TR></TABLE>
yep check these very important
Old May 19, 2004 | 11:56 AM
driftin4's Avatar
Default Re: Car smells like gas help! (krazie1)
I picked up an EF from a guy that sank a screw through the top of the tank when he installed an amp, done anything like that lately?
Old May 19, 2004 | 05:35 PM
90SICRX's Avatar
It's smelled like this for about a month and gets worse when you drive, dout it's shoes. I did a stereo install awhile but and then took it out to sell it and do engine work instead. Never smelled it while i had the system in or after it was out. It started to smell after I got it inspeced. Right before we got it inspected I put a new oem fuel rail on. But i have checked that many times to see if leaking and it isn't.
Old May 20, 2004 | 10:56 AM
89b16hf's Avatar
my car smelled like gas inside and was the gas cap it would not fully seal got a new one and never smelled it again
Old May 20, 2004 | 11:00 AM
4drEF's Avatar
Keyboard Humorist
Another thing might be the purge solenoid or the cahrcoal canister. If those don't work properly you can get fuel vapors smelling up the place. I don't know if it would create such a drastic smell like you are describing, but it's the only thing I can think of that is related to inspecitons.
Old May 20, 2004 | 11:25 AM
89civicdx's Avatar
Default Re: Car smells like gas help! (4drEF)
My car smelled like that and the tank had started to leak at the seam, I couldn't smell anything outside....check it out and get it fixed.
Old May 20, 2004 | 03:34 PM
EfLarry's Avatar
Your best bet is to take the box behinde the seats out and spray Dr. Sholls foot spray around the gas tank.I know it sounds stupid but if it is leaking anywhere the powder will show you where and how bad.Good luck.
jastonian106
Feb 28, 2015 09:03 PM
Maple50175
Apr 11, 2009 07:26 AM
IAteg
Nov 11, 2005 12:34 PM
bossman032
18
Jun 1, 2004 08:16 PM
BLKCRX
Sep 12, 2003 08:14 AM
